LQ4 crank and block qeustions
I am about to order the parts to assemble my lq4 and I thought about installing new bearings seens how I was gonna check all the bearings anyway and put in new arp rod and main bolts. I've heard good things about the cleavite h bearings but I'm not sure those would be the ones to get. The motor is a stock lq4 short block, l92 heads, victor jr, msd ls6 controller, muthat thumpr cam, kooks 1-7/8 headers, mildon oil pump, manley timing set, roller truion conversion, 10.2:1,and a quick fuel 750 race-q carb. What kind of bearing work well with a factory bottom end? also what kind of power would I have to make before I should worry about the rotating assembly?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
#2 | |
Re: LQ4 crank and block qeustions
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
