Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-02-2012, 10:42 PM   #1
gmjim4x4
Project Task Force 57 4x4
I am new on the forum. I decided to put my 57 chevy 2wd to 4wd project on a build thread. Hoping for some input as I try and finish it! The photo's I have put on are what I have done so far.
gmjim4x4 is offline   Reply With Quote
Old 07-02-2012, 10:56 PM   #2
gmjim4x4
Re: Project Task Force 57 4x4
The pictures with the cab corners are after I welded them in and then leaded around the welding. I have an NP 205, 465 Tranny combo with Dana44 and Corporate 12 bolt all out of a 79 shortbox donor. It was a 100$ for the donor pkup and only had to replace some seals and brake parts.
Old 07-03-2012, 01:44 AM   #3
argonaut
argonaut's Avatar
Looking good!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-08-2012, 01:32 AM   #4
wyomech
wyomech's Avatar
I really like what you have done ,it will be cool to see this truck on the road.
wyomech is offline   Reply With Quote
Old 10-30-2012, 10:45 PM   #5
meter swinger
meter swinger's Avatar
Any updates on this?
meter swinger is offline   Reply With Quote
Old 10-31-2012, 08:25 PM   #6
gmjim4x4
I have done some work! and I will have pics in the next couple days....
Old 11-12-2013, 12:51 PM   #7
mvitale27
mvitale27's Avatar
Jim, I am doing a similar 4x4 swap. Looking for a Dana 44 and Corporate 12 as we speak. I know I will have to relocate spring perches but do the lower shock mounts line up? If not, what did you do to fix this issue? Thanks
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 11-14-2013, 10:04 AM   #8
gmjim4x4
I did not relocate the spring perches. My Dana 44 came from a 79 chevy 1/2 ton. My 12 bolt corporate came from the same truck, and did not move the perches on the rear either.If you look at my pictures really close you can see that I left the shock brackets on the 44 and the Corp12 in the stock locations and adapted the 57 frame for the top shock brackets. The rears were simple...just stuck a new bolt in the frame. The front was a little more complicated but not very difficult. The front may be an issue if you keep the stock steering. My main issue with the whole build has been the steering. I put power steering using a saginaw box that was from 73-85 chevy 4x4's and it limits you tire size and turning right! I would suggest you go a different route. It looks to me that you can use your original steering setup and use a Toyota steering box for power steering. Orrie G has some info on that type of setup...or he knows were it is on this website. I think classic industries have the box that works for this setup. Good Luck
Old 11-14-2013, 10:29 AM   #9
mvitale27
mvitale27's Avatar
Thanks for the reply. I was under the impression that the perch to perch distances were different but that may have been when I was considering a different donor. Good info on the spring perches and shock mounts! I have been looking into the CPP power steering kit since it keeps the box in the stock location, although I havent been hearing too many good things about CPP lately.
1956 Chevy 3600
Old 12-23-2013, 09:52 AM   #10
gmjim4x4
Added some more photographs of what I have been doing.....
Old 12-23-2013, 10:01 AM   #11
gmjim4x4
Using the 1956 Hood and grill instead of the 57....yes, that is water and anti-freeze leaking out of the radiator:
Old 12-23-2013, 10:08 AM   #12
gmjim4x4
One more of the 57/56 4x4....and a couple of my next project.....65 chevy donor for my 64 shortbox 4x4 frame....oh boy (thats what my wife says)
Old 02-25-2014, 05:44 PM   #13
gmjim4x4
I am going to attempt to put a jeep CJ power steering box with crossover steering on my 57 Chevy 4x4 conversion. I will start by taking the main crossover out. The Jeep box bolts on the INSIDE of the frame. I just can't live with the 73-87 box that limits the right turning radius. If any one has any suggestions or warnings, please feel free to express your thoughts
Old 04-07-2014, 11:07 AM   #14
gmjim4x4
Have done some work on the power steering for my 57 4x4 conversion. I am using a Jeep steering box (87-95). I also got the bracket attachment that goes to the box and would bolt onto the frame of the jeep wrangler. I got both these items off e-bay and they were very reasonable. I also got the steering shaft for the jeep wrangler set up. I am utilizing all three items. This is how it looked on the first mock-up. I have since moved the box toward the engine. I found out that the radiator when mounted would not clear the box.
I moved forward a couple inches and it seems like it will work better all the way around.
Old 04-07-2014, 12:45 PM   #15
gmjim4x4
Here is a couple photo's with the box 2" back towards the the engine. I will be reinforcing the frame as well as securing the steering box once I have got the final location. (this looks to be it)
