07-24-2012, 09:21 PM | #1 |
Lets see some custom instrument clusters
I will be installing some aftermarket gauges in my 83 and need ideas and how to do this.
If anybody has pics and steps of how to go about doing this please post them up. All info is appreciated thanks |
12-06-2012, 08:48 PM | #2 |
Re: Lets see some custom instrument clusters
I would like to see some set ups too, I am thinking of going after market instruments also.
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
12-06-2012, 09:28 PM | #3 |
Stock but refaced
Posted via Mobile Device Posted via Mobile Device |
12-06-2012, 10:17 PM | #4 |
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
12-07-2012, 12:54 AM | #5 |
Take a look in my sig
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-07-2012, 02:51 AM | #6 |
not mine, found on the net...
but i love it! |
12-07-2012, 10:42 AM | #7 |
78K & 79C Jimmys
not quite stock
replaced idiot lights to gauges/tach added red LEDs as a second colour and painted inside of course for added reflection
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-07-2012, 11:14 PM | #8 |
Here's mine, All the pointers and faces match, all factory GM gauges and looks totally stock
12-08-2012, 12:35 AM | #9 |
This is my custom instrument clusters!
12-08-2012, 11:51 AM | #10 |
Wraprail, where did you come up with the 150 mph speedo? I am doing a cummins in my 86 crew cab and wanted a place to mount a pyro and boost guage so I cut the upper left double gauge piece out and grafted it into the right side where the a/c vent was then grafted the a/c vent in the bottom where the radio was. I havent got any further with the project yet as I am working on putting the drivetrain in the truck still. I hit the truck wrecking yard last summer and picked up a couple of clusters with the different gauges I wanted, just need to get it all put together. Got a 5,000 rpm tach with the little fuel gauge in it, 80 lb oil pressure gauge, volts, water temp, double air gauge, (for air ride system), then I still need to buy a pyro and boost gauge. I would like a 150 mph speedometer though, with 3.54 gears, 35 inch tires, and the .61 allison 6th gear overdrive, it works out to 144 miles an hour.
12-08-2012, 10:28 PM | #11 |
That looks cool with the extra gauges added.
I got the 150mph speedo out of an early 70s (71 or 72 iirc) Camaro Z28. I just saw one on ebay last week. Don't know if its still there. To install it I just removed the Camaro face, which is held on with 2 screws and sandwiched the truck face between. The screw holes line up as does the high beam light. You need the truck face for the mounting ears. Simple bolt in. I also took the Camaro needles and swapped them on all my other gauges so they matched. |
12-09-2012, 12:11 PM | #12 |
Thanks, I forgot to take a pic with the vent relocated. There is one on ebay, ends tonight, im going for it!I am going to have all my gauges white faced so I imagine I could just use the truck face and have the 150 sticker put on it.
12-10-2012, 07:29 PM | #13 |
INSIDIOUS86 is that tach/fuel gauge factory, if so where can I get one at?
12-11-2012, 10:25 AM | #14 |
Custom but stock looking at the same time:
12-15-2012, 10:30 PM | #15 |
Hey vaz I like that dash what type of gauges are those and what color is your bezel
12-15-2012, 10:43 PM | #16 |
Digi Tach in my cluster, silver needles, blue leds...
Pic of my test cluster i destroyed to make sure my tach would fit how i wanted it behind my custom dash bezel
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
12-15-2012, 10:46 PM | #17 | |
12-15-2012, 11:40 PM | #18 |
12-15-2012, 11:44 PM | #19 |
I leave you speechless?
12-17-2012, 06:35 PM | #20 |
Tell me more about the Tach/Fuel gauge. Did GM make one for squarebodies? If so will it work in place of the 5" gas gauge?
12-17-2012, 07:13 PM | #21 |
Yes gm did and very recently lmc truck had made reproductions of these so looking hard for one is no longer an issue. The issue is truck gauges go to 5k and not all have fuel gauges the lmc ones don't either http://www.lmctruck.com/newparts/csb/csbrpt.htm
12-28-2012, 11:45 PM | #22 |
o and now with the tach working
12-29-2012, 02:20 AM | #23 |
At the body shop.
Cut the whole dash out. 64 dash in... Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
