Old 08-12-2012, 03:25 PM   #1
mud slut 350
mud slut 350's Avatar
sm465 hydraulic clutch slave bracket
quick question. I recently aquired a hydraulic clutch pedal setup to replace my mechanical setup on my 82 k 10 with sm465. my question is i need to make a bracket to mount the slave cyl to the bellhousing without getting a new bellhousing that already has it. has anyone made one for the stock slave? novak has one but its only for their slave. any info pics or links where i could get one or a template to make one let me know please im anxious to swap this in! also do i need to make any changes in the clutch itself? in the throwout bearing or anything?
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
Old 08-12-2012, 07:10 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: sm465 hydraulic clutch slave bracket
Advance Adapters has this one that works with a stock slave. I believe it will work with a stock SM465 bellhousing too. Not too bad at $40. I have this same bracket on my NV4500 and it works great!
You can use the same clutch, release bearing and fork as the mechanical set up….Or at least I did without issue but some claim there is a different release bearing for hydro set ups which I see no difference plus the part numbers are listed as the same on the Napa and AC Delco websites.
DirtyLarry is offline   Reply With Quote
Old 08-12-2012, 07:45 PM   #3
mud slut 350
Awesome! Exactly what I need. I thought about making one but wasn't sure of the offset and all
2007 cbr 1000rr
Old 05-06-2019, 04:22 PM   #4
jdalexa84
I know this is an ancient thread but did this bracket work for the Sm465.
jdalexa84 is offline   Reply With Quote
