09-26-2012, 11:41 AM | #1 |
Steering Column upper spring
Does anyone know where I can buy a spring that is pictured?
I found this picture online and think that this may be what I am missing. Currently I just replaced my upper bearing and then put on the aftermarket steering wheel adapter but there was like a 3/4" gap. After it was all together everything was great until I slightly pulled on the steering wheel and pulled the bearing out of place which causes tons of play in the wheel. I think this spring would keep the bearing in place at all times. Any help would be great!!!! Thanks guys |
09-26-2012, 10:14 PM | #2 |
The Older Generation
Re: Steering Column upper spring
What year truck are you working on? '67-'72 Chevy trucks don't have that spring unless it is a tilt column. Unless it was supposed to come with the aftermarket wheel... LockDoc
09-27-2012, 06:59 AM | #3 |
I'm working on a 72 truck with a non-tilt column. If it's doesn't have the spring, what keeps the upper bearing from pulling out of place since ther is about a 3/4" gap between the bearing and the aftermarket steering wheel adapter hub? I also noticed that I may be missing the turn signal cancel cam. Maybe that's it?
09-27-2012, 07:01 AM | #4 |
1969 Custom 30 wrecker
I agree with lockdoc. These used a tapered turn signal cam gizmo for lack of better words that holds down on the bearing.
I once tried to install a spring to cure a wobbly steering wheel (felt like the top bearing was shot but it wasn't ) but it wouldn't work. Turned out all I had to do was loosen the column and pull it upward. That put more pressure in that area and no more slop.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-27-2012, 12:09 PM | #5 |
You guys are correct. Cancel cam holds it in place... LockDoc
09-27-2012, 12:48 PM | #6 |
So the spring is required on tilt?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-27-2012, 03:27 PM | #7 | |
Always on the hunt...
Upper steering column parts thread: http://67-72chevytrucks.com/vboard/s...d.php?t=515103 |
09-27-2012, 03:38 PM | #8 |
Thanks, good info.
02-01-2016, 09:36 PM | #9 |
But Found Her 25yrs Later!
It's available at Classic parts, but I'm not sure why the other stuff is included.
http://www.classicparts.com/mobile/1.../#.Vq_Fo3OIZnF .
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-14-2018, 02:26 AM | #10 |
Hi, does the upper steering column bearing in a 65 C10 have a spring to press down on it when putting the steering wheel on?
12-14-2018, 11:28 AM | #11 | |
Old member
Because it's for the 1960-66 Steering Column Bearing-Upper parts but it should work.
12-14-2018, 06:20 PM | #12 |
There is a spring on the bottom of the column on the 67-72. The lower brg. is supposed float on the shaft & the spring pushes the shaft down to take up any play in the streering wheel. After all these years & a horrible invironment the lower brg is practically always froze to the shaft. You might be able to loosen the clamp under the spring & tap the brg up on the shaft. Otherwise the way to fix it right is to remove the column & o-haul it.
George |
12-14-2018, 08:07 PM | #13 |
Old member
I have found that just about any GM tilt column built before they went to the key switch in the column uses this same spring.
