mini truck racer
NO-E street build
Well i have been shopping for a while and want to build a NO-E street truck ( 7.49 and slower ) I was doing the LUV search on C list and happened across this thing way down the list . I called the number and left a messae . Took about a week and i got a call . Didnt even remember the truck thinking it was a dead end . Ended up talking to the owner Russel . he bought the truck almost 3 years before with intentions of doing a V-8 conversion and life got in the way and it got stored at a friends place were out of site out of mind became the norm. I ended up getting everything arranged and made the trek 3.6 hrs away to an area outside of a small town inTexas called Lott . A good friend of mine Rodger rode with me and we Meet Russell , delbert& chris . The truck had been sitting for quit a while and both front tires were flat . I looked over the current condition and evaluated the important corrosion spots . Seemed like a good canidate . So we struck a deal , loaded it up and brought it back to Baytown . Here are the only picks i have now .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: NO-E street build
I have often thought about doing a Luv. I wonder what one would run with my current combo.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
mini truck racer
Your combo would run good in anything
Wow , what a mess . Apartently they were hualing feed when it quit running and left a bag of bird feed in the passenger side .. On the flip side The tin is so clean that the carpet retainers are still in the truck . Here are some better pics from before the clean up started . ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
mini truck racer
Got alot done yesterday . Got the old carpet out and the seat cleaned up . Vacuumed out the inside and the floor pans are spotless . If my Yellow truck is a 6 rust wise , this truck has to be a 9 . I have yet to find rust through , just surface stuff i am fixing as i go . I also got it washed . This was a job . I first scrubbed it with some purple power then regular car wash . Rotory buffed it with Meguiers #1 polish . It came out prett good . Next will be a orbital with a Cleaner wax . The main water line to the house broke and the rear Ujoint on my big Ford quit on the way home from the hardware store . Busy evening , not to mention the wife is not as thrilled about this project like i am .
mini truck racer
Got the Ford fixed and bought a LT4 Hotcam For the motor . The motor is a 96' 880 Vortec 2 bolt main with a nice set of polished and beamed older style rods and SRP 2 relief flattops . The bottom end hardware is ARP .
![]() This motor was gapped at .018 top and .022 middle so it will need some run time before a small plate gets put on it . The Lt4 hot cam hydraulic roller lifters , double roller chain and 1.6 roller rockers all linked to a set of smaller World products Torquer S/R 180 heads , Summit stage 2 mid rise dual plane , a demon 750 ( may swap to 650 ) and a MSD Hei . ![]() ![]() My tight TSI Nitrous conveter out of my Yellow truck and the fresh TH350 that was originally in the yellow truck . ![]() 31 spline 9 inch woith 3.60 street gear and a spool . The rear axle will be narrowed to fit 15 x 10 with 5.5 backspace so all my wheels will fit both trucks . This truck will be on slapper bars , but i am working with Smith Racecraft out of Dallas on a set of these bars for it on stock springs . http://srdparts.com/index.php?page=s...emart&Itemid=1
mini truck racer
Well got some done today . Woke up saturday and the wife and i drove up to Conroe , Texas . This is north of Houston and the largest fall swap meet we have . Found nothing fo a LUV . I did find a MSD billet HEI distributer with 8.8 wires and a nive like new play back tach . While at the swap meet i got a call and ended up headed back to work from the afternnon til 7 am in the morning . Got a little done on this thing . Swapped out the front side marker lights that had been spliced into for some spares i had stashed in the garage . I also dug around and found a passenger side mirror that wasnt broken . I replaced the master cylinder and blew threw the steel lines . New flex hoses , calipers , pads , seals ,fabricates 5 lug hubs with trooper rotors everything cleaned and bearings repacked with Royal purple wheel bearing grease . Here are the photos .
before: ![]() after: ![]() The healing has began: ![]()
mini truck racer
Just some clean up pics .
Before flor pans : ![]() After: ![]() Engine compartment ![]() ![]()
mini truck racer
Got more done this weekend . Cam swapped in the motor . Ended up going LT4 hotcam . Motor is just about finished .
![]() Also picked up the rear axle . 85 Ford F-150 4 x 4 gave this one up for $150 . I have 3.60 with a spool , 4.20 spool and the 3.50 that came in this one . I cleaned up the backing plates and added new wheel cylinders , spring kits and shoes followed by turning the drums . All the front brakes are now new , except for the tubing . This includes rotors , bearing , calipers , seals , hoses, master cylinder , dot 3/4 synthetic fluid . ![]() And a sneak peak at how things are shaping up . ![]()
mini truck racer
Dis assembled the 9 inch today washed it out and bought new ends . Ordered new Strange axles and dropped housing off at the race car shop to be narrowed . New strange ends were also purchased . Gear is already set up with a spool and 3.60 gear . Rebuilt truck drums will be on the ends .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 11-16-2012 at 03:21 PM. |
mini truck racer
More cleaning . The broken air shockes were removed and the new/old ones from the Yellow truck were installed . All the poly tubing from air shocks removed . The rear section of the wiring harness was a mess . These trucks have the seperate turn signal brake light and require a converter box for trailer lights . Looked like there was 15 splices back there . I had the tail light harness off a 78' a buddy of mine parted out that was a Texas A&M campus maintience truck ( wornout ) . It was prefect so in it went . Both the side marker lights in the rear were not working due to broken wires . Had replacements as everytime i find one of these trucks i buy the lenses . Actually got the wiring cleaned up and working . Thinking the 4 cylinder might run . I found a good home for the motor here in Houston/Tomball . A father son restoration of a stock 1978 with a automatic . They are on Luvtruck.com and the parts will be helping there project .
Ordered a new oil pan , valve covers , breathers , air cleaner , roller rockers . This should be the last of the big stuff pending the radiator .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 11-16-2012 at 03:36 PM. |
You have been hard at it! It should be a fun little truck.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
mini truck racer
The racing has kinda slowed down so i have been working on it . I work rotating shifts and the wife and i are empty nesters now so i have alot of time alone to work on it . Hoping the motor makes around 350/360 to the ground . Should run some 11.80-90's and have power brakes and a/c . Im going to drive this one more .
#13 |
Looking good.. Will be fun once in action!
#14 |
wow brings back a lot of memories... my brother had a white luv with a 350 and auto trans... pretty much stock with all bolt ons when I was 15 (1985)... he would run mid 12's all the time and won a few trophys at the high school drags..... I all ways wanted it but never got it cause he wrapped it around a pole... survived no injuries but the truck was toast
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#15 |
mini truck racer
Got a little more done on the drivetrain this week . Rocker arms are on and valves adjusted . The oil pan was from a caprice or roadmaster with the sensor in the pan and i couldnt get it to stop leaking . i replaced it with a new truck pan . i am waiting on the valve covers and breathers to come in and it should be close .
![]() Also got the housing narrowed and the axles came in . The bearings are not correct , so i will have to wait for them to come in or buy them local . The axles should have come assembled and ready to install . I dont have a press so i have no idea what im going to do there . I double flaired the factory brake line with a standard 3/16 end to allow the use of an F150 brake flex hose . ![]() ![]()
#16 |
mini truck racer
Wrapping up the motor .
#17 |
mini truck racer
Got this far today .
#18 |
^ That'll do, pig.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#19 |
mini truck racer
Not very romantic , but all the lights and signals now work except passengerside rear side marker . The wires are off it . I will solder it back up and re install it . The left turn signal indicator in the dash is bad so i will get it fixed , Got the horns working . Stock motor is locked up solid . More clean up and 1/0 battary cables built .
#20 |
mini truck racer
Got a bit farther along . The motor mounts were used and cut out of another truck . A budy of mines son Shawn is in metal shop class and he used the motor mounts as a project in metal shop . I got the hood off and more wiring done . All the lights are burning now . most of the stock motor is disconnected and ready to be pulled . Wife had me doing yard work most of the weekend , so no huge steps , but it iscoming along . Stock motor which is locked up about to come out .
![]() ![]() All the key player having a meeting before moving in . ![]()
#21 |
mini truck racer
Havent had alot of time for this truck lately but got a few things done . My Vortec block had no provisions for a fuel pump at all . No fuel pump rod hole or pump mount holes at all . I drilled and tapped the block for the fuel pump block off plate . The A/C bracket im going to use mounts to the fuel pump boss and the 2 holes in the front of the motor . Also the motor mounts will be the polyurethanes off my Yellow truck . Getting closer to the install .
#22 |
mini truck racer
Got a bit farther today . The Chevy Luv/Izusu rear axle is basically a Japanese copy of a Ford nine inch chunked in the oven and shrunk . I pulled the old assembly out and set the new axle on the moroso spring perches , with 1/2 " u-bolts and the Afco lower shock mounts that came on the Yellow truck . The emergency brake cables from the Luv snap right in the big Ford backing plates and the cables slide right in the cam arms for the e-brake of the drum brakes . Ill get some pics of the brakes coming up , but a photo update . 28 x10.5 x 15 slicks
![]() ![]() ![]() 275 60 15 drag radial ![]() ![]() ![]()
#23 |
mini truck racer
You can also see that after being cleaned up and buffed out that it has it's fair share of body damage . Most of the damage was hide when it was dirty .
#24 |
mini truck racer
Dash cap and radiator came in today along with the carpet and door panel material . The material is a 70's/80's mopar pattern that caught my eye 95% of people will never know it is not factory , the other 5% wont care .
![]() ![]() Here are the original door panels . The kick panels will also be upolstered to match . ![]() Waiting on the A/C and alternator brackets to come in . Still need a fan , mufflers , sump for factory tank , Have been working 7 days a week and not had time for this , plus santa claus is coming and my girls are back in town for a while .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-19-2012 at 10:52 PM. |
#25 |
dazed and confused
I like this truck
members met: redbaron69, billsbowtie,nc67 |
