Old 11-18-2012, 01:57 PM   #1
volker
volker's Avatar
"Bittersweet" 83 dropmember blown LS 22s
This is my latest project it's well on its way
volker is offline   Reply With Quote
Old 11-18-2012, 02:00 PM   #2
1981Stepside
1981Stepside's Avatar
Re: "Bittersweet" 83 dropmember blown LS 22s
Looks clean. Specs? Plans?
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 11-18-2012, 02:08 PM   #3
volker
volker's Avatar
Truck has front and rear porterbuilt drop members ls1 with heads cam magnacharger and its sitting on 22" billetspecialties turbine rims
Old 11-18-2012, 02:11 PM   #4
volker
volker's Avatar
Old 11-18-2012, 02:12 PM   #5
volker
volker's Avatar
Old 11-18-2012, 02:16 PM   #6
f.monroe
f.monroe's Avatar
Nice! Keep the pics coming and maybe go ahead and include a couple of that F-- d in the background.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-18-2012, 02:18 PM   #7
volker
volker's Avatar
Old 11-18-2012, 02:22 PM   #8
volker
volker's Avatar
Here's with the 22s on at rpm
Old 11-18-2012, 04:06 PM   #9
1981Stepside
Wow - looks great!
I have one question though - I might catch hell from all the guys with bagged squares -
I only ask because I've had experience with hydraulics, not airbags - but can you really take advantage of a huge HP engine, whether an LS or not? I mean, isn't there some diminished handling characteristics with airbags? So isn't all that monster HP kinda wasted?
Old 11-19-2012, 12:07 AM   #10
DIRTY HAIR
very nice truck
DIRTY HAIR is offline   Reply With Quote
Old 11-19-2012, 12:49 AM   #11
andrewmp6
With air bags the more psi in the bag the higher the spring rate gets.Handling can be better with air bags if its set up right,Ridetech took a 4th gen camaro and ran it down a slalom bone stock then put their air ride kit on it and ran it again.The air ride one did better times.
andrewmp6 is offline   Reply With Quote
Old 11-19-2012, 01:40 AM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
Originally Posted by 1981Stepside View Post
Wow - looks great!
Air bags CAN handle great but when they are aired up to get a proper spring rate for handling they sit to high and a static drop car with static spring rates is already at its ride hight so it will outperform bags with ease
Airbags = great stance nice ride and moderate handling
Springs = harsh or soft ride. Moderate stance great handling when setup that way and a good stance with about the same fab as bags
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-19-2012, 08:47 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
The ride height of an air'd up bagged suspension will depend on the suspension,... not the bag.
Any Porterbuilt chassis has a lower ride height than my bagged blazer at full dump.
Keith
Convert to disc brakes.
Old 11-19-2012, 11:03 AM   #14
volker
volker's Avatar
heres a few shots of the bed
Old 11-19-2012, 11:06 AM   #15
volker
volker's Avatar
i went with new bed sides front wall and gate and the crew at rpm designed and did the metal work inside
Old 11-19-2012, 11:07 AM   #16
lolife99
lolife99's Avatar
Killer work,... like always,... from the guys at RPM.
Keith
Old 11-19-2012, 11:14 AM   #17
volker
volker's Avatar
heres the bed complete
Old 11-19-2012, 11:34 AM   #18
andrewmp6
That's one of the nicest beds i seen on here in a while.
Old 11-19-2012, 12:08 PM   #19
silvereagle07
silvereagle07's Avatar
Sweet! Like the bed fabrication but what is the hole in the middle of the notch and the rear slots for?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 11-19-2012, 12:17 PM   #20
7deuce
Sold! 2 days after finished
7deuce's Avatar
Gas cap....
7deuce is offline   Reply With Quote
Old 11-19-2012, 12:19 PM   #21
JCampbell
Sick.
What's the deal w/ that Bronco in the background? Looks interesting.
JCampbell is offline   Reply With Quote
Old 11-19-2012, 03:13 PM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That thing is amazing....
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-19-2012, 04:01 PM   #23
volker
volker's Avatar
hole in the rear is gas cap and , the slots in the front and rear are mac trac's ill post a pic of them there flush mount into the bed
Old 11-19-2012, 04:11 PM   #24
INSIDIOUS '86
Exactly if your air susp is built for handling then it will handle great but if your aired up or aired halfway it will still be slightly softer than a coil system and will lean more. And besides it kinda defeats the dual purpose of bags by setting it up as such bags give you stance at the shows and good ride and ground clearance around town
Old 11-21-2012, 05:46 PM   #25
volker
volker's Avatar
i took a few pics today theres a shot of the mac's track that flush mounts into the bed , not sure if ill have them polished or powercoated yet
a pic of the gas cap and the boxes RPM made to go in the fuel doors left side is air fitting to fill the tank kinda back up and a air gauge to show tank pressure and the right side is battery jump terminals and flaming river kill switch and those are painted flat like the engine bay will be
