99+ disc rear end for 67-72 trucks
Has anyone or do you know of anyone who has a 99+ style disc brake rear end in their 67-72 model truck. I think this would be ideal since they are strong and have disc brakes so no need to a disc brake kit and you can still retain the 6 lug. Anyone have any info on this?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 99+ disc rear end for 67-72 trucks
I think you will need to check the width
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
yeap, narrow it and itll work.. i have a 99 rear disc set up for my colorado. narrowed total of 18inches..
width is 66" over my 62" rearend. Not only could that give me disc brakes but it would make my front to rear track widths close to even and not have to run staggered wheels. Any recommendation on how id do the brake lines? Ive never messed or adapted brake lines, but have some knowledge of changing them. Id also order CPP rear mount kit to weld the perches on. Thanks guys
Fabricate till you "puke"
Try to get all the lines/hoses with the diff, for pattern....My 02 has 3 hoses on the rear(1 ea end, & 1 in the center). One of the outer hoses was a dealer only deal, but the other 2 came from Oreillys. You may have to adapt the fitting (from the rear line to center hose), to get the proper threads. The other thing I found, is the alum calipers (with age) tend to stick. Save a few bucks & purchase "loaded calipers" on the rebuild.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
1 more thought....that 99 has 16" wheels . A 15" wheel will probably not fit over the caliper. Again,best of fun playin
do you have this style rear end in your old truck? I guess if all else fails i cant make custom brake lines. Im sure this swap would be cheaper then putting a posi and disc brakes on my stock rear end.
Someone here sells a kit to put disc brakes on the 12 bolt, I think it's captn fab. Uses impala or? Calipers
No sir, I have that style rear under my stock 02 silverado? I do know that you are playing with metric fittings tho... too bad you are not closer to my spot in Illinois! I have the calipers(core only), & the lines & hoses & useable rotors.If you were close enough to pick em up, they would be yours for the "takin" (NC). crazyL
Truck 10-bolts come with a Eaton Gov-Loc Posi, Or affectionately known as a Gov-Bomb. Not worth installing in your truck Just to have this happen.........
That dont look good! I have 1 of those 'gov bombs" in my truck.....I dont crowd it too hard tho (just a daily driver)
#13 |
Thats some tasty looking carnage.
#14 |
The Engine Whisperer
The Right Stuff makes a 6lug disc brake conversion. http://www.getdiscbrakes.com/trd4706
-Automatics win races, 6-speeds impress high school kids -Save a tree, support your local dragstrip. -"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui columbuscarsandcoffee.net and on Facebook |
#15 | |
![]() Bloodybigblock.....Disc brakes are not worth the work to install a 10-bolt under your truck. If you got to have Disc brakes, CaptainFab makes some brackets to do that to your 12-bolt, Add a Yukon Dura-Grip posi & your in business. 71/72 diffs are wider & will solve the width issue, Buy a core rear & build it up a little at a time. |
#16 | |
#17 | |
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#18 |
#19 |
All jokin aside, I do have to agree with clinebarger....the 12 bolt would be a better build
#20 |
Cline- you need a stouter cart! That baby's seen better days!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#21 |
Naw....that will "buff out"
#22 |
what about a 14 bolt rear from a 90s model 3/4 ton?
#23 |
