Old 01-06-2013, 08:44 PM   #1
robert_63
robert_63's Avatar
tcc brake switch 85 c10
anyone know about this switch? Can I just use my factory brake switch since the truck had cruise control? I purchased the switch for a camaro that i found a part number to on here, but the factory switch has 3 prongs on the end of it that i assume is for the cruise control, and the two other prongs that are for the brake lights, seems to me i can just use my switch and wire off the three prongs on the end.
robert_63 is offline   Reply With Quote
Old 01-07-2013, 02:24 AM   #2
ls1nova71
ls1nova71's Avatar
Re: tcc brake switch 85 c10
Yes your original switch will work since your truck originally had cruise. Just remove the cruise plug and hook the TCC through it. Then if you want to run cruise you can use the LS cruise.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-28-2013, 03:44 PM   #3
izzy_Britton
izzy_Britton's Avatar
What is the LS cruise?
i am seeking a brake switch for my cruise control / TCC and this thread popped up on google. Napa doesnt have the switch that is a direct replacement for my switch and cannot cross reference one that will work.
your explanation would be greatly appreciated.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 09-28-2013, 05:59 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
he means cruise control from the LS motor, not using anything off the old trucks.,
I would also get rid of the three prong switch in favor of a 4-prong switch. It makes wiring the cruise easy. Also, the cruise on the ls motors is DRASTICALLY different if you are running a drive-by-wire system....in that case the cruise control boils down to a couple of toggle switches.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-28-2013, 07:27 PM   #5
ls1nova71
ls1nova71's Avatar
Not sure what yourw working on, but if its the 86 in your sig , just get one filor an 86 with cruise. Are you doing an LS engine swap?
Old 09-28-2013, 08:46 PM   #6
mooseknuckles
mooseknuckles's Avatar
mooseknuckles is offline   Reply With Quote
