02-11-2013, 08:37 AM | #1 |
Chummins Build
I started a build thread on c10forum but I think i will continue the build here on 67-72. Seems c10forum is flooding with only a handfull of users therefore I would like to share with you guys.
I believe i will just start by uploading some pictures and giving a brief discription. Feel free to comment, i love criticism. This was the day i brought the truck home (Fall of 2011) This is the motor I ran last summer. 307/296 high comp heads, weiand, noisey gear drive. Donor truck. 92d250 5.9 pulled. Replaced rear-main seal, changed fluids motor and trans. Upgraded to 13" flywheel & South Bend Clutch |
02-11-2013, 09:03 AM | #2 |
Re: Chummins Build
Picked up and '87 c20 rolling frame for dirt. 8lug disc brake front 3/4 ton clip and corp 14 bolt full float rear. Scrapped the frame with the dodge and made my money back plus some.
Doghouse removed 3/4ton clip from the 87 frame rolled right under and bolted right in place. Only had to drill out 2 holes and redrill 1 hole per side. Setting the cummins inplace After mounts were built the only major issues i had was a front cross brace and turbo hits heater box. Bent a plate and placed between balancer and brace. heated with torch and lowered motor down to bend it out of the way. Transmission: used factory th350 crossmember. Flipped upside down and actually bolted into where the transfer case may have mounted from factory |
02-11-2013, 09:13 AM | #3 |
Re: Chummins Build
Mocking the 14-bolt in place
Sleeved the trailing arms. Also served purpose of guide pins Panhard bar built. Gotta love friends with lathes. |
02-11-2013, 10:12 AM | #4 |
Re: Chummins Build
Great build photos so far! Will be watching for more.
02-11-2013, 10:19 AM | #5 |
Re: Chummins Build
11" booster from MBM. Need to make some modifications to the bracket or cut another hole in the fire wall. The linkage runs about an ince above the factory hole. Therefore need to cut out the hole in the firewall or drill new holes in the bracket.
Added a return line back to the tank and a vent line since my cap doesnt work correctly Running the HE351 off 04.5-07 cummins. Had to get a flange machined that clamped to the back of turbo and build my downpipe from 2-4" 90* and a couple inches of stright. Also had to make the oil line to the turbo and modify the oil return from the turbo. Oiler housing had to be clocked about an hour&half so the inlet was at 12 o'clock |
02-11-2013, 10:23 AM | #6 |
Re: Chummins Build
Looking good. Looks like a LOT of work but will be worth it in the end.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-11-2013, 10:27 AM | #7 |
Re: Chummins Build
I will be running 4" exhaust behind the rear tire (as it should be). I didnt want it to hang low so i welded a piece of 6" pipe in the crossmember for the exhaust.
Hello Downpipe This catches up to date. I did finally get a chance to fire it up and after getting the air out of the lines she ran pretty good. Plan on painting inner fender tonight and putting doghouse back on tomorrow. Then I can start mounting the inner cooler and do some plumbing! |
02-11-2013, 11:24 AM | #8 |
Re: Chummins Build
I am loving how detailed the build is. Cannot wait to hear more
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
02-11-2013, 11:28 AM | #9 |
Re: Chummins Build
Nice work
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
02-11-2013, 10:01 PM | #10 |
Re: Chummins Build
Thank you for the kind words. This is my first build out of my own pocket. Im 25, father of 2 (2&5) and work over 12 hours a day... so needless to say my shallow pockets are made up with pride in my own work.
Posted via Mobile Device |
02-11-2013, 10:10 PM | #11 |
Re: Chummins Build
Very nice would love to do this to a old truck.
02-12-2013, 10:39 PM | #12 |
Re: Chummins Build
Got doghouse set on. First just have to say I could start a small hardware store with all the bolts I removed just for the grille. Anyway it is out of the way to start fitting the IC. Also I can see I will be looking into drop kits foe the front. About 5" from fender lip to tire.
02-13-2013, 02:00 AM | #13 |
I have a radical idea!
Re: Chummins Build
Awesome work! Your diesel swap was a little more involved than mine! -lol
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-17-2013, 08:47 PM | #14 |
Re: Chummins Build
IC in place
Had to cut up a perfect core support but the 2nd gen IC fits. My old electric fan wont fit anymore. Anyone know of a good skinny fan? Posted via Mobile Device |
02-18-2013, 04:50 PM | #15 |
Re: Chummins Build
Electric fan. That is the idea i had for my 67 C30 but i settled for a 454.
02-18-2013, 10:26 PM | #16 |
Re: Chummins Build
How much room do you have from fan hub to radiator?
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
02-19-2013, 10:28 AM | #17 |
Re: Chummins Build
Heres a picture i had on my phone. not sure exactly from the fan hub. The radiator is in factory location. These diesels run cool so i wont need much. i found 2-10" dia x 2" thick e-fans for under $40. Whatever i do get will be on a temp switch so they unless they need to. |
02-19-2013, 11:14 PM | #18 |
Re: Chummins Build
A Cummins Fan!!!!!! Yay!! Good choice on a first gen motor. I owned a 93 my self. If ya need any info on motor mods hit me up. When I sold my truck it was a healthy 400hp motor.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
02-19-2013, 11:29 PM | #19 |
Re: Chummins Build
Nice build and great work. What is the expected mpg on a Cummins in one of ours?? Thanks
Ed F 1972 Sierra Grande White Top Medium Olive 402 bb / Camper Stock, Loaded, Straight & Aged Nicely, No Tilt Original Resto would be nice $ |
02-20-2013, 12:03 AM | #20 |
Re: Chummins Build
Why would you want to put a cummins in a chevy?
02-20-2013, 12:27 AM | #21 |
Too many projects
Re: Chummins Build
Glad to see another Dodge getting scrapped and the only good part going into a Chevy. I love my 68 K20 with a 12 Valve. Tons of torque and great mileage!
A side note: I strongly encourage you to run U bolts over the rear axle as I wouldn't trust bolts holding down the axle once you play with the torque of the motor. Other than that it looks awesome and this is the fan I used for mine: http://www.speedwaymotors.com/Ultima...-80,42296.html 91015682 from Speedway Motors; expensive but it fit the stock Dodge radiator very nicely and when it actually has run (rare unless a trailer is hooked up) it easily cools off the engine. I have very little room between my engine and rad and it works great.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
02-20-2013, 12:51 AM | #22 |
Re: Chummins Build
OMG that is close!
02-20-2013, 08:10 AM | #23 |
Re: Chummins Build
Good to see some other swaps out there.
Ackattack- your crew cab is looking good. LowRollin- Yours too. What turbo do you have? You said it was from a Cat right? |
02-20-2013, 08:50 AM | #24 |
dazed and confused
Re: Chummins Build
Looks good!
members met: redbaron69, billsbowtie,nc67 |
02-20-2013, 11:14 AM | #25 |
-Praise the Lowered-
Re: Chummins Build
I'm impressed! Will be watching this one...
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
