02-28-2013, 12:51 AM | #1 |
1970 Daily Driver
Spark Plug wire Supports and Retainers
Trying to find the supports, retainers, and heat shields shown in this diagram to run the ignition wires under the ram horn exhaust and still be supported and protected. The motor is a 327 out of a 1967 Impala. I got the wire set from NAPA for a 1977 corvette.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
02-28-2013, 12:53 AM | #2 |
Re: Spark Plug wire Supports and Retainers
Subscribed.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
02-28-2013, 12:55 AM | #3 |
1970 Daily Driver
Want it to look like this picture
This link helped a lot. http://67-72chevytrucks.com/vboard/s...d.php?t=295089 Now I just need to find where to buy them
02-28-2013, 08:59 AM | #4 |
I need to look but i thing i have what you need lmk if still needing ?
02-28-2013, 09:35 AM | #5 |
We stock all 3 styles of the spark plug retainers and the heat shields that you are looking for. You'll find them listed on the following page of our web site
http://www.gmcpauls.com/Engine_&_Tra...ion_Mounts.htm They are the first 4 items on that page. Paul Jr @ GMCPauls |
02-28-2013, 10:20 AM | #6 |
Just for reference, the picture in post 3, wires for numbers 1,3,2,4, should be run between the motor mount and the block.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-28-2013, 10:53 AM | #7 |
1970 Daily Driver
Thanks GMCPaul! How much is it for the full set?
02-28-2013, 10:53 AM | #8 |
I bought mine here. Truck Shop. Use late 70's vette wires if you run an HEI.
http://www.truckandcarshop.com/trucks60_72/t60_097.html
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
