Old 03-02-2013, 09:27 AM   #1
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
painting leaf springs
Anyone dissasemble and paint their leaf springs?? Any luck or tips??
Anyone use teflon spacers btwn each leaf?
I wonder if the leafs will end up rusting no matter what you do??
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 03-02-2013, 09:28 AM   #2
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Painting leaf springs
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 09:34 AM   #3
ecgate
ecgate's Avatar
Re: painting leaf springs
I would think your best best would be to powder coat them.
ecgate is offline   Reply With Quote
Old 03-02-2013, 09:51 AM   #4
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
i've heard of power coating no being very flexible and cracking if flexed. Is this true? Anyone else heard this??
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 10:12 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
I would think powder coating would crack too on a leaf spring or any kind of spring.
I have always had good luck with black engine enamel and do have to touch them up on occasion. I have never taken mine apart before but its not a bad idea to get complete coverage of each leaf.
I guess it depends on the intended purpose. Is it a show vehicle or just a nice driver?
TBONE1964 is offline   Reply With Quote
Old 03-02-2013, 10:18 AM   #6
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
I guess it depends on the intended purpose. Is it a show vehicle or just a nice driver?[/QUOTE]
It will hopefully be somewhere in between...
I just hate the look of rust under the truck, and springs end up looking very rusty...
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 10:27 AM   #7
chevyman91
My buddy owns a powder coating business he powder coats coil springs all the time with no problems. But I wouldn't think it would last long.
chevyman91 is offline   Reply With Quote
Old 03-02-2013, 10:32 AM   #8
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks guys.
I think ill try the KBS coatings on them and see what happens..
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 12:15 PM   #9
I just hit them with low gloss black engine enamel.
Old 03-02-2013, 12:25 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Powder coating lasts pretty well. I've done a bunch of them for folks. Powder coated springs along with new plastic liner (Speedway Motors) will make them look nice and ride smoothly.
Old 03-02-2013, 12:35 PM   #11
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
For the plastic liner are you talking about this stuff from speedway
http://www.speedwaymotors.com/Flat-S...ners,7471.html
Are you using it for the entire lingth of spring or just above the perch?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 01:10 PM   #12
Tx Firefighter
This is the type of stuff that I'm talking about....
http://www.speedwaymotors.com/Leaf-S...nch,39823.html
I don't see where they offer it in 2.5 inch wide anymore. Might have to find a different source. But, this is the stuff. I line each leaf end to end.
Old 03-02-2013, 01:42 PM   #13
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
thanks
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-02-2013, 02:26 PM   #14
Re: Painting leaf springs
Here are answers to the same questions:
http://67-72chevytrucks.com/vboard/s...d.php?t=568656
Old 03-05-2013, 02:34 PM   #15
6600DURAMAX
6600DURAMAX's Avatar
Mine are powdercoated, seem to work just fine since it is parked in the garage everyday. hahaha
Pictures are kind of blury but you get the idea, all broken apart and reassembled with teflone between each leaf. They are black gloss with a clear coat on top
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-05-2013, 02:43 PM   #16
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Is the teflon bwtn each spring similar to this stuff? If so, how did you get it to stay in place?
Nice truck by the way!
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-05-2013, 02:46 PM   #17
6600DURAMAX
Yup that is the stuff, I just drilled a hole and slid the centering pin thru them as I assembled the leaf springs
Old 03-05-2013, 04:15 PM   #18
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Thanks for the info..
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-05-2013, 05:01 PM   #19
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Did you use the teflon for the entire length of the spring, or just above the perch for about 8" or so?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 03-05-2013, 10:00 PM   #20
danw210
69 K20
I just did mine. I used Masterseries coatings and I think they turned out great. I think that the Masterseries will hold up better than powder but I guess time will tell (also a lot cheaper than powder coating). Heres a picture of mine.
danw210 is offline   Reply With Quote
Old 03-13-2013, 01:58 AM   #21
tgfeller
I'm planning on por 15 for mine, though I am curious about the length of liner to use, and if you should use it between each leaf
tgfeller is offline   Reply With Quote
