Old 04-01-2013, 07:49 PM   #1
David623
Body mounts
I got some body mount bolts and bushings but don't have a clue where the different length bushing goes and bolts go. Anyone has the right information I would appreciate. I am building a jig mimicking the frame's body mounts. The tub needs extensive rebuilding, and the manual I bought shows a picture but does not have sizes.
David623 is offline   Reply With Quote
Old 04-01-2013, 08:42 PM   #2
notsolo
notsolo's Avatar
Re: Body mounts
a page from LMC and a post from a couple years ago....67-72chevytrucks.com/vboard/showthread.php?t=362908
notsolo is offline   Reply With Quote
Old 04-02-2013, 07:29 AM   #3
David623
Re: Body mounts
Unfortunately they do not give the size of the bushing when you click on the part.
Old 04-02-2013, 09:10 AM   #4
GMCPaul
Re: Body mounts
Well out of the 5 bushings used on either side of the main body the front bushing on either side is the only ones that are not the same thickness as the other 4 positions they use the thickest upper bushings in the front position on either side, the 4 rear upper bushings on either side are all the same thickness, if you have the radiator support bushings also the 2 upper bushings for it are the 2 smaller diameter bushings.
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 04-04-2013, 08:19 AM   #5
David623
Re: Body mounts
Thanks for the information, I am building a jig to mimic the 72 frame, I am rebuilding the tub and will be able to roll the tub 360 degrees so I can weld in the flat.
