Old 04-04-2013, 12:49 AM   #1
1965c1O
Solutions for axle wrap
1965 c-10 with a 70's rear end.
To drop it, the original owner removed some leaf springs and the 3 on each side are pretty "bouncy".
When stepping on the gas medium to hard, I get axle wrap - and I can see the u joints are slightly bent.
What are some on the budget solutions for this?
Are traction bars the best way to go?
Is there a way to find used traction bars?
Any other ideas?
Also, does this mean I loose a lot of power in most conditions or only on a hard take off?
Thank you.
1965c1O is offline   Reply With Quote
Old 04-04-2013, 07:06 AM   #2
Re: Solutions for axle wrap
I've used something like these shown. They mount over or under the leaf,depending on u-bolt type,using the u-bolts and front spring perch. First ones were called Bushwackers,then Rancho was selling them. You could easily fabricate them.
http://www.hotrodsandhemis.com/traction6.jpg
http://www.novaresource.org/ct/ct02.jpg
http://www.rockymountainsusp.com/images/SL_tracbar.jpg
These last ones are like what I've used. Rocky Mountain Suspensions has them. They're made by Superlift.
Old 04-04-2013, 08:04 AM   #3
69GWC
I would install a new set of springs and lower it the correct way and then see if it still does it.
69GWC is offline   Reply With Quote
Old 04-04-2013, 11:12 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Your ujoints are bent! Throw some spicer lifes in there asap and have the shaft reballanced.
Throw some cal tracks on it to get rid of the wrap.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-04-2013, 10:54 PM   #5
I'm thinking he meant "u-bolts"
Old 04-08-2013, 09:16 PM   #6
1965c1O
Anyone know where I can find these used, maybe someone parting out a truck ?
Old 04-09-2013, 09:41 AM   #7
biohazardbill
Convert to coil setup?
Should be pretty easy to do.... and parts are easy to find and cheap since 99% of chevys came with that setup from factory back then.
biohazardbill is offline   Reply With Quote
Old 04-09-2013, 12:26 PM   #8
Ackattack
Ackattack's Avatar
I was going to suggest that too. I converted my 69 from 3/4 ton leaf to 1/2 ton coil. You should be able to get the parts used pretty cheap, but there are a few crossmembers you have to remove along with the leaf spring hangers. All are attached with rivets, which can be a pain, especially if you don't have an air chisel.
Ackattack is offline   Reply With Quote
Old 04-09-2013, 12:53 PM   #9
Mike C
Mike C's Avatar
Caltracs will solve your hop problems. One great thing about leafs is how much room you have to route exhaust.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-09-2013, 02:43 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I hope he meant u-bolts. If the U-joints are "bent", that's a breakdown waiting to happen.
Caltracs are spendy. So can swapping over to coil springs. The el-cheapo way would be to install a universal set of "slapper bars".
Find a spring/suspension shop in your area and have a set of drop leaves made for your rig. That might be a tad cheaper than buying aftermarket dropped leaves as well.
This is one area you wanna make sure you're doing it right.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-10-2013, 08:53 AM   #11
The traction bars I showed are the cheapest and by far easiest suggestion so far. Converting to coils is a lot of work in my book. A lot of parts needed,a lot of work,and how to you fasten the panhard bar to a leaf spring axle?
axle, tractio
