where to find "soft" 5 inch rear drop springs
I know I can purchase a drop spring from most of the vendors but reading the "how to make it handle" thread the mention of using softer rear springs came up a couple times.
The spring rate info does not seem to be published. Mention of a Chevelle rear spring were made. So what springs should I buy? Do they differ vendor to vendor?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Happy to be here
![]() Join Date: Mar 2000
Re: where to find "soft" 5 inch rear drop springs
You might check out some Jeep springs. If I recall thats been a common swap because the Jeep guys are adding lift springs and the stock ones can be found cheap or free.
I have read that they give you plenty of drop, but they are on the soft side. If you use them and they don't work, at least you could get an idea of what spring rate you will need.
Thanks for that I will see if I can check into finding some. They are an easy swap I just was not sure where to look.
cpp, i just sold mine but they were just to lower and not for performance so they were not stiff
great springs, had them for 4 years installed with hauling and no sagg http://www.classicperform.com/Chevy-Truck.htm#28
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
Grandpa in the rustmobile...
JMO, I think the jeep springs are too soft even if your not hauling anything......
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Thanks John. I will probably just order some drop springs and see hotter they work
Thanks John. I double post
Any particular reason for 5" springs? Hotchkis makes 6" springs that are "softer".
http://www.hotchkis.net/6772-c10-rea...l-springs.html
Thanks Matt for the link that looks like that is what I was looking for. I know you get what you pay for but that is a few times the price of a "standard" drop spring. I will need to give this some thought I don't know and can't seem to get the spring rate of these other springs. I don't know how much difference in the rates there are.
I do happen to have a testing lab I can probably get an exact spring rate on any of these. We do leaf spring testing and get that info all the time for those. I can use the same stuff. I may look into that to see what I can find out. I think 6 inch would work fine I just didn't want to get too low (if that is possible) Thanks Dave
the hotchkins springs are a little stiffer than the conventional drop spring because they are for performance and handling.
the cpp springs just mimic the stock springs and actually have a very smooth ride
C/10 junkie
I can tell you from experience that the CPP drop springs are much softer than the ECE drop springs.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
![]() ![]() Join Date: Jan 2011
I can tell you from not so much experience the Hotchkis springs are curved all the way to the top and are a nice shade of gray.
![]() I have them in my truck, but have yet to drive it. ![]()
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#13 |
I have some jeep springs back home in TN there yours for shipping but it wont be till june until Im home.
#14 |
Thanks for the offer John, that is great. I will get back with you then and see. I think I am going to go ahead and order some I found that have the spring rate listed and seems to be in line with what I was looking for. I will try them out and if they don't work maybe the Jeep springs will be the way to go.
#15 |
CPP makes soft springs.
Tags |
drop, handling, springs |
