Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-29-2013, 08:08 PM   #1
RICKSRAT
RICKSRAT's Avatar
Goodyear Drag Radials
Got the Goodyear 315/60/15R drag radials mounted on the new 12" Centerlines this weekend. Was quite a chore for the tire guy to get them to seat but he got it done. Hope to get back to track soon to see how they do. I have not run any drag radials so hope I can get them to work on truck ok.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 04-29-2013, 08:15 PM   #2
RICKSRAT
RICKSRAT's Avatar
Re: Goodyear Drag Radials
Goodyear 31x 14 on 14" wheel compared to 315/60/15 Goodyear Drag Radial on 12" wheel.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 04-29-2013, 08:20 PM   #3
RICKSRAT
RICKSRAT's Avatar
New Centerline 15x12 &. 315/60 drag radial
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 04-29-2013, 11:46 PM   #4
Super73
Super73's Avatar
Word of advice, either take some power out and slowly bring it back in and/or lower you ICG a little to take some hit out of the tire.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-01-2013, 08:53 PM   #5
dinnut
dinnut's Avatar
Good luck! Let me know when your getting ready to go out there again. Did you get your stuff back from Wilson yet?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 07-05-2013, 04:39 PM   #6
RICKSRAT
RICKSRAT's Avatar
Pic of new wheels and Drag radials. Looking to go to the track in a couple weeks to try out new tires. Also changed front shocks to single adjustable Strange engineering from Comp's and added frontend limiters.And sent Nitrous system to Wilson and had both systems flowed for a better starting point for tuneup. Looking to try both systems next time out to see what it will do on the drag radials.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 07-05-2013, 06:16 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Me likey... lookin' forward to hearing how they do at the track.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-06-2013, 06:31 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
I was out there last night . You might consider test and tune at the next bracket race . The track got bald quick . There was a slick spot in the right lane at about 600-700' . Getting ready for OTM ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-06-2013, 10:55 AM   #9
RICKSRAT
RICKSRAT's Avatar
Hey Hotrod may make the 2nd or 3rd weekend in August. Also looking to go July 12 or 19 to try to get some passes in. And yes looking at running in October at the OTM. You looking at running the OTM?
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 07-06-2013, 12:09 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
We have a night race Aug.3rd That would/should be decent prep . I am actually working for OTM . I wish i wasnt't cause i would have all three of my trucks out there in a class .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-06-2013, 12:35 PM   #11
RICKSRAT
RICKSRAT's Avatar
So Aug 3 would be best time to go? What time is the track open. What are you doing at OTM?
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 07-06-2013, 02:44 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Aug 3rd will be all sportsmen racers with slick tire cars . Track prep should be decent to good . I will be at my income producing job during OTM . I work rotating shift .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-06-2013, 03:29 PM   #13
RICKSRAT
RICKSRAT's Avatar
So they also run TnT on brackets also? May try to make it on the 3rd working days but may try to make it after,what are the track hours?
My bad thought your meant you were working the event I work 12 hr rotating shifts also so know what you mean on the income producing job.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 07-07-2013, 06:49 AM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
They run test and tune between rounds and gates open at 1 and racing starts at 3 pm and will run til late when finished . They will run test and tune til about the semi finals or so 11 ish . Heck you might even just pay for the footbrake or super pro tech card . You will get 2 time trials and get to run first round . Never know might end up going rounds . If not just put TNT on the window and run between classes .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
