Old 05-02-2013, 08:25 AM   #1
BP87GMC
BP87GMC's Avatar
Front set up ? Also:
If pie cuttin the upper improves the ball joint angle, does it also lower the front at all? And if I pie cut, so I need to do anything to the lower?
BP87GMC is offline   Reply With Quote
Old 05-06-2013, 08:33 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front set up ? Also:
No.
Pie cutting helps to keep the balljoints from binding when air'd out.
I have no idea what year truck you are working on,... but most C10's will not lay on the front crossmember, but the lower a-arms.
Keith
Convert to disc brakes.
