05-22-2013, 09:39 PM | #1 |
Fantasy build questions
If you wanted to build a short box truck that could keep up with the fastest production cars in the us what would you put in the truck if money was not a obstacle?
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world! |
05-22-2013, 09:39 PM | #2 |
Re: Fantasy build questions
582.
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax |
05-22-2013, 09:50 PM | #3 |
Turbo 6.2l
Rb30dett Posted via Mobile Device |
05-22-2013, 10:12 PM | #4 |
lol you've got to be kidding!
05-22-2013, 10:13 PM | #5 |
GoatLube Experss
agreed, but with a blower .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) Last edited by jitteryguy; 05-22-2013 at 10:14 PM. Reason: spell'n |
05-22-2013, 10:14 PM | #6 |
he did say to (keep up with) the fastest production cars....
05-22-2013, 10:16 PM | #7 |
A day should have 30 hours.
Build to the t!ts 3UR twin turbo with a T-56 Magnum
05-22-2013, 10:21 PM | #8 |
GoatLube Experss
the option's are endless for the 6.2L, with 424HP and 424ft-lbs torque in stock form.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
05-22-2013, 10:26 PM | #9 |
LOL, pretty sure the 6.2L suggestion is not referring to the IDI diesel but rather the LS motor.
On that note, I would probably look into a Lingenfelter crate engine.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
05-23-2013, 12:02 AM | #10 |
KEEP UP WITH? for how long? we talking 1/4 mile race here or cannon ball run? neck & neck or just be able to catch up and keep up?
anything other than a race down a drag strip, for dependability, i would stick with a 6.2, custom built 6 speed manual trans with uber tall final, a gear vender or something similar, and uber tall gears in the rear diff. might take you a week to get to speed but once there you could cruise at low R's with good economy and SOME pedal left. LOL but again who knows. everything depends upon criteria of how and when. JustBlowingSmokeIzzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
05-23-2013, 12:21 AM | #11 |
Nelson engines. i'd order up a 1500 hp twin turbo 427
05-23-2013, 01:12 AM | #12 |
LS
DEAD serious thought about building a RB25DET, but I really don't feel like losing money on my 350 Posted via Mobile Device |
05-23-2013, 02:03 AM | #13 |
Supercharged LS7 with a 4L80E, Gear Vender, 4.11 geared Fab 9 rear, would work for me..
05-23-2013, 06:15 PM | #14 |
i forgot there were a few different 6.2s, i would go with an 8.1 too, or a duramax with efi live
05-23-2013, 06:18 PM | #15 |
Chevy 350 and Big Block engines are probably one of the most commonly built and raced engines on the planet, so it's not the engine I'm worried about. It's the suspension and handling, how would you get your squarebody to corner like it's on rails?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
05-23-2013, 07:50 PM | #16 |
plenty of guys are doing it. im just getting started on mine
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
05-23-2013, 07:58 PM | #17 |
John 82 Chevy Silverado 350ci/TH350 Last edited by J Knight; 05-23-2013 at 08:07 PM. |
05-23-2013, 08:33 PM | #18 | |
Grab a C30 swaybar or buy a aftermarket version. Truck arm suspension is said to be a great option, but a good 4 link is another. I would try 17 inch rims for the larger selection, and run 200 treadwares. |
05-23-2013, 08:52 PM | #19 |
Square
ls
Squarebody Syndicate |
05-23-2013, 10:40 PM | #20 |
LS9/tr6060/9inch
05-23-2013, 11:41 PM | #21 |
For those who have asked, this thought came after watching bull run and all the racers with turn key cars, and I started wondering if one could build a square that would be just as fast and reliable as those $200000 sports cars and could handle as well and still keep up on a 3000 mile road race
05-24-2013, 12:46 AM | #22 | |
Is with suspension mods to any decent starting point you can go very far. Mind you your C10 likely won't beat a $120,000 Porsche, but you'll be so close to his backside he draw his belt tighter. You just need to run high quality tires with a low tread-ware. Yes the LS is a better motor in just about every aspect, but it is not the only route there. A good turbo on a stock iron 350 with get you 500hp. Don't fall in to the Vtec trap. HP is HP. Don't matter if its a 1950's flat head. If it puts out more then you factored in with vehicle weight. Your still going to loose. Build a engine you like, and are will to deal with afterwards. If you budget is limited build the suspension first. There is a ton of cheap parts you can grab from the junkyard that will turn a basic C10 into a killer. Also a 2400rpm stall converter on a basic 350 will run. |
05-24-2013, 12:59 AM | #23 |
Twin turbo ls7 type build. With a 200-4R trans and 373s. Vfn fiberglass hood and an aluminum front end. Lightened wherever possible with a tonnue and smoothed underside. One tank will hold race fuel and the other will hold pump gas. All I do is manually add boost and timing on my computer and switch gas tanks and run 700+hp then swap it again for 450 low hp good mileage. You don't need aerodynamics with pure power making the guy in the Lamborghini wondering wtf just happened
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-24-2013, 01:09 AM | #24 |
My original idea for my truck which is a 74 C20 was to turn it into a factory part monster.
C20 brakes are bigger, and with a 9.5 14 bolt with K20 rear brake conversion. It would stop fast enough, and cost 1/3 the price of a C10 big brake kit. The frame is thicker, and helps with keeping the suspension doing its job. Plus I will fully weld the joints for further stiffness. Move the suspension points like I said earlier, and learn to drive what you built. A good driver is more important then the car 1/2 the time. If you don't get used to your cars characteristics you never be able to push the limits. It won't have the finesse of a super car, but it will surprise you with what it can do. My wife says I can't have 2 slammed trucks so my C20 is becoming a Rally inspired build, but with all the suspension mods I can afford. Or dream up, and get close to what my vision entails. 20 some years ago I read about how NASCAR used to modify stock parts, and how homligation rules made certain tricks necessary. Which afterwards I never looked at large vehicles the same again. Big brakes for hauling weight now slow you down real fast. Its all about set-up. Also do research on what ever vehicle you are using as your performance target. You'll see most of the vehicles are not light weights, and while your truck will not be so light. You will only be about 10% heavier if you try, and pay attention. |
05-24-2013, 09:58 AM | #25 |
Alot of those are good ideas.. but he did say if money wasn't an option....
I would run the no limit engineering frame, or something similar, cage the entire thing from front to back to keep and frame twist down.. with a blown lsx built to my standards using an RHS race block.. running a supercharger of the sorts thats undecided, even though i am partial towards top mounts, (ineffeicient thought) I would build in a weight transfer in the frame so i could dial in cornering weights, not to mention to move the engine back about 6-8 inches. relocate as much as possible to the rear of the frame for a better weight distro. And of course wheels and tires to your liking, but keeping the tires around a 40 series so i have some sidewall to take in bad city streets.. Thats a good start.. |
