Old 06-03-2013, 09:39 AM   #1
4oldcars
4oldcars's Avatar
Air bag operation
I've got this Blazer (2wd) that already had air bag suspension installed. I'm old and air bags just ain't me. I took out the front ones. Went back to springs. I'm gonna keep the back ones so I can tow. I currently have the original set up - - 2 air compressors, air tank, etc. I'm wondering if I could/should remove all the above (poor installation and take up a lot of space) and just use a schrader valve to air up the rear bags. Anyone been there, done that?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 06-03-2013, 11:43 AM   #2
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Re: Air bag operation
Easily, just run the two lines from the rear bags to somewhere around your license plate, install the schrader fittings and you're good to go. No need for compressors, tanks, relays, or anything.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 06-03-2013, 10:58 PM   #3
cst69
Hollywood
cst69's Avatar
You could possibly "recycle" the 2 pumps and tank.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
1968 cSSt shortbed
1971 custom deluxe shortbed frame off
1991 caddilac escalade ST shortbed
1992 chevy ext. cab Project: leftovers
2003 Silverado ext. cab shortbed (my dad's truck R.I.P.)
1969 trans am clone, pro tour
1985 Yamaha Vmax, custom
1993 Yamaha Vmax, showbike
1969 Sears Suburban SS12 lawn tractor
cst69 is offline   Reply With Quote
Old 06-05-2013, 02:15 AM   #4
andrewmp6
You could do that if it was me i would find a small tank and compressor which is easier to hide.
andrewmp6 is offline   Reply With Quote
Old 06-05-2013, 08:10 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have the rear bags only also, for towing. I have two schrader valves at the rear license plate.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-06-2013, 09:02 AM   #6
4oldcars
4oldcars's Avatar
I'm assuming by your comments that 2 valves are better than one. I had in mind to tee the lines to one valve. Not a good idea? Thanx for tha comments.
4oldcars
Driving:
The ones I let go:
Old 06-06-2013, 09:27 AM   #7
SCOTI
SCOTI's Avatar
T'd airlines allow shift of air pressure from side to side when there's leaning (in a corner) thus making the issue even worse. 2 valves (or separate airlines w/schraders) isolate each bag independently.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-07-2013, 10:07 AM   #8
4oldcars
4oldcars's Avatar
Thanx SCOTI. As usual, I wasn't thinkin ahead. Sounds like a plan.
4oldcars
Driving:
The ones I let go:
