Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-04-2013, 12:17 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
pump gas SBC need opinions bad
I got a buddy with a torn up SBC . He wants a pump gas motor that is still drivable , makes enough vacuum for power brakes and makes 500+ horse power . Stay with me on this cause it is happenning .
Here are the stipulations :
Must be carb to pan , jetted and tuned
wants a warranty of some sort
really wants decent parts ( made in USA )
Must be hydraulic cam or low maintience to a certain extent ( for a high HP motor)
budget is $10.000
right now he is looking at the Blueprint series from summit . I am thinking Ohio crank or one of Scott Schaffroff's Hydraulic roller deal . LS is out of the question due to chassis configuration . Conventional SBC
Think some have insight on a better combo or package .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-04-2013, 01:34 PM   #2
Super73
Super73's Avatar
Re: pump gas SBC need opinions bad
I notice you say LS is out due to chassis. What's it going in to? Is it out due to a class spec or are they not willing to look in to motor mount adapters and headers. Most cases those two things are really the only issues for most platforms.
We both know a low maintence reliable 500hp is not super difficult from an LS and 10k budget.
Just sayin.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-04-2013, 01:37 PM   #3
ripdog28
ripdog28's Avatar
You could do a pump gas LS with a turbo for less but then look at the computer work, trans, lots of little extras will add up fast in doing an LS swap.
If sticking with an old engine, You can not beat this deal. The owner is one hell of a guy as well. The 406 is at the bottom of the page.
http://www.vortecproperformance.com/...binations.html
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-04-2013, 02:15 PM   #4
kevin9574
http://www.sunsetracecraft.com/
all they show on their site is big blocks but they've built a ton of pump gas smallblocks
kevin9574 is offline   Reply With Quote
Old 06-04-2013, 02:51 PM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
AN LS engine does not fit in the platform ( LUV ) and the cost to front half, headers,mounts,adaptors, hood , firewall, would be way over budget. I have an LS motor now and they are great just not an option with out distroying the truck
Very feasible , just not an option
Just sayin.
No room for a turbo , intercooler , centrifugal super charger , or roots blower . NO LS & no NOS on this one 23* SBC big inch . Wonder what block they use in the 406 .
Good looking stuff
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-04-2013, 02:53 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
This will be going in my WHite Luv i just sold . The guy is now chasing ET and wants to go 11.0 to 10.90 and still be pump gas and street friendly
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-04-2013, 03:06 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
Pumpgas friendly 23° sbc with enough vacuum for power brakes, street driver friendly and 500+ honest HP..... under $10k.... He dont want much do he!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-04-2013, 04:51 PM   #8
PrettyRicky
hotrod80.......pm sent
PrettyRicky is offline   Reply With Quote
Old 06-04-2013, 05:23 PM   #9
funnyfarmracer
My old luv truck went 6.30's with a 331 sbc. Ported iron heads, solid .555 cam, had a lil bit of compression but it would run the number on nitrous. The truck ran 7.40's on motor. I actually drove it to rankin quite often from tomball so it was streetable. So with that being said I think a 406 with some afr 195's, a good hyd roller, and a good drive train should easily run the numbers your looking for and save some money. IMO
funnyfarmracer is offline   Reply With Quote
Old 06-04-2013, 07:50 PM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
That Vortecpro 406 won't pull enough vacuum for PB. I asked!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 06-05-2013, 12:48 AM   #11
Captainfab
60-66 Nut
Going hydroboost is really fairly easy.
Old 06-05-2013, 02:00 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Right , looks like we are going to do something like a 383 with 210 AFR's and a big hyd roller
If it gets spray it will be a fixed 100 shot
If hydro boost is belt drivin then no-go . There is only room for 2 groove pulleys with out rebuilding the entire core support .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-05-2013, 02:05 PM   #13
ripdog28
ripdog28's Avatar
Vacuum canister? If not, I am sure a call to Mark Jones, Vortecpro, could put a different cam in there and make more vacuum. still probably be above 540hp.
69 c-10 BBC
Old 06-06-2013, 01:09 AM   #14
Captainfab
60-66 Nut
Hydroboost operates off of your power steering pump.
Old 06-07-2013, 06:47 AM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
Doing a pump gas 383 with an AFR 210 .
If power steering type pump would be used it would have to be a high mount and remote resivor sprint car type deal . There is no room down low .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-07-2013, 09:07 AM   #16
Marv D
Marv D's Avatar
I tried for 500+ with a flat top 6" rod 383 with the old AFR 210's (box stock not the cnc program) flat milled to 68cc. Zero decked it wsa just over 10.2 compression. Cam was a Crane hydraulic roller at 236/248 @ 0.050 and .585/.61 lift. With a single 4150 we couldn't get it over 480HP on the dyno. Around 6200-6300 we started having valve float with the big ol SpeedPro hydraulic rollers and the light hydraulic rollers springs AFR supplies. Later I tried a set of heavier springs but it still felt like it was nosing over around 6500. Not enough cam, not enough spring, running out of head..... I don't know? It was enough for the time and effort anyways.
Point of all that is I'm sure a better combination could make the 500. But like everyone, I think the vacuum is going to be the issue. If I were going to try it again,, I'd probebly just jump straight into a SHP with a 4.125 bore and 4" stroke. I really am starting to like the Brodix STS 233 heads on a big inch SBC. There a pretty decent 'right out of the box' head. But that would probably kill his $10k budget for sure.
Old 06-07-2013, 09:22 AM   #17
hotrod 80
mini truck racer
hotrod 80's Avatar
I was able to tame down the ever elusive 500hp at a savings of $4000 . The truck is a leaf spring slapper bar deal that gets drivin to the track and ran on street car night . He just wants to run11.60's and no cage .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-07-2013, 01:05 PM   #18
hotrod 80
mini truck racer
hotrod 80's Avatar
Mine is nosed over at 6200 rpm right now . I hate to even say this out load , but i have over 550 passes on the valve springs . I am buying the 64 cc chamber 210 eliminators and a dish so if he hurts this new 383 he can stick them on a flat top 350
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
