![]() Join Date: May 2005
07 Cruise Control Problem
So my 07 wont allow the cruise to work. Ive checked all threads, read through the "easy fixes" , I have replaced the brake light switch and still no go. I have tried to trouble shoot it to the best of my ability, but I have not been able to make it work. According to everyone else with the problem, its as simple as the brake light switch. Anyone else have any other ideas? Thanks
Re: 07 Cruise Control Problem
any ideas??? Still cant figure out the problem.....
Was it part number A/C Delco# D1586H, GM# 15861245. All you need is a 10mm wrench and a small screwdriver to pry the clip apart? Is that the part you replaced?
58 Apache short fleetside ona 64 chassis: ![]() |
Yep. That was it. Still wont work.
Still have not made any progress yet. I cant get this figured out.
Collector of Projects
I would be interested to know as well. Just bought a high mile 08 Sierra RCSB... the little light on the steering wheel comes on... no light on the dash to say its engaged....
check your brake fluid level. if the level is low, it will not allow the cruise control to engage.
no fuse. I have a light for my abs on also. I have read that the speed sensors go out and that could be the problem as well. But they are expensive.....
If the speed sensor was not functioning, the transmission wouldn't be shifting correctly and the speedometer wouldn't be working...
Someone on another board asked if brake bulbs were swapped out recently? My turn signals flash at a fast/erratic rate and it looks like my right rear tail light had water in it (looks corroded)... I'm thinking it may be part of my issue... Last edited by mcmlxix; 09-03-2013 at 06:24 PM. |
Thats a good point. I will take a look at my bulbs tonight. I know the lense on my passenger side has a small crack and hole in it.
