Old 07-11-2013, 12:56 AM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
ACC Build: 1950 Chevy
Hey guys, decided to wonder from the dark side (60-66) to keep you posted on one of our customer builds .... its a hodge-podge, but yet very cool.
It's a 1950 Chevy truck, powered by a Nailhead, switch-pitch T400, explorer axle, mustang II, and Dodge 20" spare wheels .... Stay tuned for more pics as soon as I get PhotoBucket organized ....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-11-2013, 01:00 AM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: ACC Build: 1950 Chevy
Thanks for posting, Chief. Just curious, whose Mustang II kit is it?
Dan in Pasadena is offline   Reply With Quote
Old 07-11-2013, 01:08 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
First off, let me fill you all in on the details.
The truck came to us with the front and rear suspensions done.
The booster/master and all hard lines installed.
Our job is to pick up the ball, and finish the truck to a "driveable mock-up" state.
In other words, the customer wants to cruise it for a bit, enjoy it, make some changes if any ... then have is blow it all apart for full powder/paint.
More info soon !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 09:41 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The day it was delivered .....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 09:49 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Work began by prepping the Nailhead to mate to the TH400 Switch-Pitch tranny. The triangle shape plate was removed, and the crank ground to except the pressed in conversion bushing ....
A quick call to engine supplier confirmed my hunch ..... the lip had to be ground flush....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 09:56 AM   #6
mknittle
mknittle's Avatar
Looks like it is going to be pretty cool. I am a big fan of anything different!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-11-2013, 02:44 PM   #7
skymangs
skymangs's Avatar
Damn... Love that nailhead, Very old school. I have plans to build a 401 nail for one of my upcoming AD projects.
skymangs is offline   Reply With Quote
Old 07-11-2013, 03:45 PM   #8
Daze57
Daze57's Avatar
x2 ^
Daze57 is offline   Reply With Quote
Old 07-11-2013, 09:17 PM   #9
1project2many
Very cool build. Love nailheads and it's always fun to see another one on the road.
The switch pitch 400 is a fun trans. I've got one in a '79 Monte behind a 455. I manually switch stall modes using a floor mounted dimmer switch but most guys like automatic operation. Most cars with the switch pitch originally had a throttle position based switch but a vacuum based system similar to what's used with TCC on the 700R4 would work very nicely imo..
1project2many is offline   Reply With Quote
Old 07-11-2013, 09:47 PM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The owner picked up this used Nailhead from nailheadbuick.com, Buick specialist. It was guaranteed a good used running engine. He also supplied a rebuilt set of rockers, and some other goodies.
We did reseal of the engine, and also a timing chain as it was a little sloppy.
After pulling the pan, we got a little scare....Milky, milkshake !
The engine was pressure washer prior to delivery to us, and a look into the crankcase and under intake confirms it was from the wash ....
OH NO !!!!!
"IT'LL BE FINE !!!"
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 09:56 PM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
SNEAK PEAK ......
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:00 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Removed carbs, and tapped the bottom of manifold to help hide the booster vacuum line ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:09 PM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Jump around a bit .... HARNESS INSTALL
Customer brought us a Speedway harness, not too bad for the money. He supplied a 20 circuit (way to much) but it has a harness plug for the accessories, so there isn't a boatload of extra wiring.
The firewall was smoothed, so mounting to it was out of the question, but I still wanted it high up under dash.
I bent some rod, and fabbed up a simple plate to located from side kick to column brace .... Fuse panel is on a tilt to be viewed easily
Removed door to make my life easier:
That gonna be perfect ! (notice steering wheel)
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:16 PM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The kit did come with a headlight and hi-beam switches....Ignition was purchased separate.
Four holes were drilled to give me option of position. I chose horizontal to tuck wires easier...
Just one step to make a late model switch fit...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:21 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I came down the kick and under the cab corner to 'hide' the harness...
Tank removed to simplify ...
Solder/shrink .... only way to go !
Not exactly sure where to exit the wires, so I decided to go out rear ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:26 PM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
More random shots ....
Front layout ... routing under frame...
More Soon .... I'm tired ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-11-2013, 10:45 PM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The owner informs me it is from Jim Weimar ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-12-2013, 02:14 AM   #18
Coach529
Coach529's Avatar
Nice looking build.....subscribed!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-12-2013, 07:52 AM   #19
Katrina/10
Katrina/10's Avatar
Thanks for posting all those pics!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-12-2013, 08:28 AM   #20
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
No prob .... thanks !
There is a lot more, but I'm only posting the 'impotant' ones ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-12-2013, 09:54 AM   #21
youngrodder
youngrodder's Avatar
I love the looks of this truck, especailly the engine. These AD trucks have sooo much head room in the engine bay that this motor set up works great to take up some of that room. Plus it looks cool to boot.
Keep feeding us pics.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-13-2013, 12:42 AM   #22
D-CHEESE
Dammmm...You white cats do some good work !
D-CHEESE is offline   Reply With Quote
Old 07-13-2013, 10:04 AM   #23
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Uhhh, thanks !
We lucked out in the location of our shop, as it is the first stops of the delivery trucks when they pull into town ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-13-2013, 10:11 AM   #24
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Temporary coolant lines were made until the body is finalized, which at that point hard lines will be made.....
Also, we will try and located a straight neck for the T-Stat ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 07-13-2013, 10:19 AM   #25
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Misc .......
What the heck, lets light up the interior ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
