Old 03-25-2002, 09:55 PM   #1
nate68
Post temp sender for vortec
what temp sender do i use in the head with vortec heads that will work with my temp guage? the thread is a different size than normal small block heads (i cant think of it off the top of my head) i cant put the temp sender in the manifold cuz it will interfere with my radiator hose.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-26-2002, 09:41 AM   #2
Blazer1970
Blazer1970's Avatar
Post
I have never been able to find one that has the same resistance as the stock sender. I used the closest one I could find, and added a big wirewound resistor to the back of the gauge to correct the gauge. I have details somewhere, but not at hand right now.
Blazer1970 is offline   Reply With Quote
Old 03-26-2002, 10:06 AM   #3
Mixup
Post
I have Autometer gauges and had no problem with the sender. The hole is smaller then regular heads so I didn't have to use an adaptor.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 03-26-2002, 10:32 AM   #4
HuggerCST
HuggerCST's Avatar
Post
You could use an adapter, or a thermostat housing that has a hole for it. It wouldn't be in the head, but it is an option.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-26-2002, 10:55 AM   #5
tom hand
CCRider
tom hand's Avatar
Post
You could use regular pipe fittings from a hardware store. You would need a reduction coupleing and a close nipple. It would not be pretty but if you put it on the passager side it would be in the back and not as noticeable.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-26-2002, 03:54 PM   #6
rustfree
Post
had the same problem with my heads/temp sender and the lack of clearance under rad. hose so had my machinist buddy cut out a 1/2" aluminum spacer (used gasket as template) for under the hose connection on intake. Works slick and matches the polished manifold too!
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
Old 03-26-2002, 05:42 PM   #7
Custom 68
Custom 68's Avatar
Post
Mine is not a Vortec but I have mine in the water neck on the intake. Is there any disadvantages to doing this is the output good? My truck always runs VERY cool according to my gage. I dont seem to have anyother place to put it. The ones under the upper radiator hose are well under the radiator hose and wont fit.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-27-2002, 12:56 AM   #8
SoCal71K20
Post
nate68,yeah I too am having the same problem.
Our old heads were tapped 1/2 inch pipe thread and the vortecs have a 3/8 inch pipe
threaded hole.I have no clearance for temp.
send unit and reducing fitting since I'm
running headers.Be nice to find 3/8 temp.
send unit to work with stock gage.Blazer
1970,how did you do that again?
SoCal71K20 is offline   Reply With Quote
Old 03-27-2002, 04:29 AM   #9
Ron's68
Ron's68's Avatar
Cool
I used one from an 87 chevy. It works fine. I just went to kragens and they found it for me. It is from a 87 truck or camaro. Hope this helps.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, and gear drive to annoy the neighbors.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, 4.10 posi and gear drive to annoy the neighbors.
Ron's68 is offline   Reply With Quote
Old 03-27-2002, 10:57 AM   #10
SoCal71K20
Post
Ron's68, are you using that sending unit with stock type temp. gage?
Old 03-28-2002, 12:16 AM   #11
Ron's68
Ron's68's Avatar
Cool
yep. And it seems to run in the same temp range as the one I had in my stock heads.
Old 03-28-2002, 04:03 AM   #12
nate68
Post
i'm usin one from like an 88 vette, says its running cooler than before. of course it takes longer for it to warm up with these heads. one of the disadvantages of vortecs, also guideplates dont fit with stock style valve covers.
