09-30-2013, 08:27 PM | #1 |
Fitting 15x10 Rallys on a '72 Blazer 2WD
Hi, all. I've got a question I could really use some help with.
I've recently inherited a 2WD '72 Blazer from my dad (he's still with us, btw), and upon going to pick it up, I ordered some 15x10 Rally wheels with 5" backspacing to throw on for the drive home. They fit (and look) great on the back, but it was on the front that we ran into some issues. The wheels won't fit up front due to hitting the steering knuckles on the spindles (I think that's what they'd be), and it appears possibly a little bit on the brake calipers as well. Do any one of you fine, knowledgeable individuals out there know what I can due to fit these wheels on this old beast? Thanks! |
09-30-2013, 08:35 PM | #2 |
67-72 parts collector,…
Re: Fitting 15x10 Rallys on a '72 Blazer 2WD
5" bs is too much for 15" wheel.
Nothing will make it work.
09-30-2013, 08:39 PM | #3 |
Well that's discouraging! Maybe a 15x8 with 4" backspacing for the fronts?
09-30-2013, 08:43 PM | #4 | |
Even then you will probably have to trim the lower a-arm around the balljoint.
09-30-2013, 08:43 PM | #5 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-30-2013, 08:47 PM | #6 |
09-30-2013, 08:52 PM | #7 |
Wed have to go thru the proper channels, as for sale threads are not allowed on the messageboard
09-30-2013, 08:56 PM | #8 |
09-30-2013, 10:54 PM | #9 |
Got pics, and will you take the tires off....
03-28-2016, 01:06 PM | #10 |
Did you ever get it figured out? Im working on exactly the same thing. Any photos? Thanks.
