11-19-2013, 08:21 AM | #1 |
scotts hot rod vs porterbuilt on the front
Im trying to compare the 2 kits.
scotts is bolt in and comes with a rack and pinion setup. porterbuilt is the famous drop member. Why would I go with one versus the other. Lets assume this will be on a autox c-10. I know both are board members so im not trying to start a pissing match. I've done biz with scotts and they are great to work with. nate has taught me a ton through the posts on this forum. |
11-19-2013, 10:44 AM | #2 |
67-72 parts collector,…
Re: scotts hot rod vs porterbuilt on the front
I'm not sure how you answer a question like that without starting a pissing match.
I'd contact each Vendor and discuss with them what you want to do.
11-19-2013, 02:08 PM | #3 |
no limit, ride tech and the roadster shop make bolt in front kits also and all of them auto cross.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-19-2013, 03:06 PM | #4 |
Yea.. I see this turning into a pissing match. There are members on this board that are loyal to each company.
///Relaxed Atmosphere |
11-19-2013, 03:53 PM | #5 |
haha. I really wasn't trying to stir the S@#$. I'll let this thread die painfully.
11-19-2013, 11:28 PM | #6 |
11-20-2013, 09:19 AM | #7 |
I would use either if i had the cash,Only things different i see is nates you gotta cut a notch in the frame weld in a boxing brace for the rack.And scotts you just bolt it all in no cutting or welding.Things to look at are like ball joints do they run off the shelf ones or something special.
11-20-2013, 10:20 AM | #8 | |
11-20-2013, 10:35 AM | #9 | |
The Mild and Touring versions do not.
11-20-2013, 10:47 AM | #10 | |||
We have three different variations of the Dropmember for different ride heights, and two different variations of geometry for each kit to meet the specific goals of the customer. Basically we make different kits or variations to meet the different needs of the end user.... not just one option. We are making some big changes to our web site to help explain the differences of each and advantages/disadvantages of each variation. Until the site is updates, just give us a call or shoot us an email and we can help you find exactly what you need. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
11-20-2013, 01:18 PM | #11 |
I agree. It's tough as a manufacturer to have a "comparison" discussion without coming off as sour. If you have any specific questions regarding our product, ask away. If you would like a detailed version, go ahead and give us a call.
I think the hard truth is that nowadays, every option is going to probably be light years ahead of what was available 10 years ago; so you probably can't go wrong either way. I know that Nate puts a lot of effort in making sure his product is top notch as well as we do. In the end though, they are 2 completely different designs and you'll want to decide what suits you the best. |
11-20-2013, 03:27 PM | #12 |
and for the record there's Robs (no limit) stuff as well. So many choices and all board vendors. arrrrgh.
