Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-01-2013, 10:50 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Transmission Filter Gasket Issues
I have a 2008 Sierra with the 4L60e. I went to change the trans fluid and put in a new filter. The gasket for the filter will not come out of the transmission.... All I did was mangle the existing gasket. I'm sure its the original because the filter is date stamped November 2007...
Is there a trick? A special tool? I don't want to destroy the aluminum around the port....
help...
Rich
1972 K5 Blazer CST Click HERE
Old 12-03-2013, 12:11 AM   #2
sleepertruck72
sleepertruck72's Avatar
Re: Transmission Filter Gasket Issues
This tool made it very simple for me. Stick the hooked end on the lip of the gasket, hit the tool with a hammer,., it should come right out...
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 12-03-2013, 02:22 AM   #3
mcmlxix
mcmlxix's Avatar
Thanks.. I unded up using a 3/8 carriage bolt and a large flat washer... worked great. Got the idea from You-Tube...
Rich
