Old 12-17-2013, 04:21 PM   #1
crazy longhorn
Fabricate till you "puke"
69 longhorn ls swap(pics)
Here are a few pictures for the swap ...Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-17-2013, 04:23 PM   #2
crazy longhorn
Re: 69 longhorn ls swap(pics)
here are the other two
Old 12-17-2013, 04:49 PM   #3
tinydb84
tinydb84's Avatar
Can we see more pics of the truck? Your signature sounds badass
David
Instagram: myfabguy
Old 12-17-2013, 05:35 PM   #4
crazy longhorn
There were some pics on Web shots, but I think they are long gone now? If you punch in Illinois Longhorn, there is a walk around clip on U-tube. Late @ night, its pretty dark, but give an idea about the truck overall & exhaust sound @ idle... longhorn
Old 12-19-2013, 02:29 AM   #5
crazy longhorn
Everybody screams for pics? We all know that there are a dozen or so different ways to do this swap I hope that the pics on the fit will help the next guy playin.....will run down some specs on the build. Note that she is running, but not done On the mounts/stands that I have,I would not recommend the engine that deep to the firewall. My firewall was recessed, in the mid 90's, for a BB Olds that was set deep. The 383 that I ran after that set good in that spot, but a little tight on the HEI. I pulled the trans crossmember 1" forward (holes were there in the frame), & slotted the stock I6/250 stands forward. I then added 1" to the front of the stands, for the eng mount to sit on. The block plates are a Carshop Inc part, with a urethane mount set. Hooker street rod shorties, with a set of mandral bent downs connect the headers to the rest of the system. The pan is a GMPP hotrod pan (H-3 Hummer). The bell housing is a 1955 cast(car bell), that bolts the 6 spd Richmond trans. This one was done a little differenty , than most are....but any questions on fit/clearances, I am here to answer. Sorry about the carb on that little "fuelie"....but she sounds like a cruiser to me Longhorn
Old 02-26-2014, 09:09 PM   #6
crazy longhorn
BTT, one more time for pics/fitment on exhaust....Longhorn
Old 02-26-2014, 10:03 PM   #7
71chevystep4x4
71chevystep4x4's Avatar
Glad to see someone else used those headers!! I've brought those up a few times on the many (swap headers) discussions on here, and everyone wants to spend $400 on a set of long ones. Although I had to build my own 2 1/2" reducers because mine came with 2 1/4", plus I pointed them straight down instead of at the oil pan.
71chevystep4x4 is offline   Reply With Quote
Old 02-26-2014, 10:20 PM   #8
crazy longhorn
Amen brother, those headers fit around the gen 1 clutch linkage, on my 2wd truck...(a big thank you, you showed them to me)! I also went 2 1/2" on the pipes..(speedway motors , stainless tubes). The tubes are mandrel bent... (90 down, & about a 30 kick on the bottom)? They hit the stock pipes really damn close to where the headers were on that Gen I ,383 Longhorn
Old 04-01-2014, 06:44 PM   #9
crazy longhorn
BTT, for eng placement/firewall clearance...Longhorn
Old 04-01-2014, 09:45 PM   #10
woodwright
Enjoying left field
woodwright's Avatar
Do you have any pics or info on your tilt nose?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-02-2014, 04:47 PM   #11
crazy longhorn
I am sorry to say, no I don't have any build pics on the clip. It sure was a pile of work tho... That's what slow winters are for, I guess ? Longhorn
Old 12-14-2014, 03:05 AM   #12
SUB LDO
Longhorn, do you have a part # for those headers?
SUB LDO is offline   Reply With Quote
Old 12-14-2014, 02:29 PM   #13
crazy longhorn
Hooker#2312 (painted), or #2313 (ceramic coated). The painted versions can be had for around $225, Summit, Jegs, or Carshop inc. I did blast & recoat mine with a high temp bbq grill paint to give a tougher coating. Longhorn
Old 12-14-2014, 02:48 PM   #14
SUB LDO
Thanks!
Old 12-14-2014, 07:39 PM   #15
crazy longhorn
No trouble I have to ask tho...what yr truck are you playing with? longhorn
Old 12-14-2014, 07:51 PM   #16
SUB LDO
A 69. I will start a build thread soon, just collecting parts now.
Old 12-14-2014, 08:15 PM   #17
crazy longhorn
Anything , that I have been through, I will share with you Just ask? Longhorn
Old 12-14-2014, 11:43 PM   #18
SUB LDO
Much appreciated.
Old 12-20-2014, 05:06 AM   #19
crazy longhorn
Some guys don't like to see the carb , on that little "fuelie", but all in all she is a very smooth ride! The line angles are right on....& you have to love on the screamin gears? For the guys that ran that m-22 Muncie, the Richmond is south on 1st gear (3.28), &.76 in OD....2-5, are very close to that old Muncie trans. The old truck, is a tad old school....a mix , from 30-40 yrs....my build/my feelings, on what I like? at 3000 rpms, she will cruise 100 mph, all day long in OD....on the same hand, in the lower gears, dance the loud peddle & you can twist that old truck sideways Longhorn
