Old 12-26-2013, 01:07 AM   #1
Yellow72C10
Rebuilt or crate?
I know this question has been asked plenty, and if there is a thread to help me, please let me know.
I have a 72 chevy 4wd short stepper. Original 350/350. Finally have some real money to throw at it, and a good portion will go to engine and trans.
So the question is, rebuild the current 350, and if so, keep the old qjet? If I did this, I'd have to change it up and add some power later.
Or, get a new crate 350 and be done? Have Anouilh power to turn the tires and not have to worry about a 40 y/o block. Although, can the old th350 handle this?
Any experience is helpful! Thanks!
Yellow72C10 is offline   Reply With Quote
Old 12-26-2013, 09:15 AM   #2
eldogg
eldogg's Avatar
Re: Rebuilt or crate?
What are your goals and budget for your truck? Power, MPG, gear ratio, tire size.
eldogg is offline   Reply With Quote
Old 12-26-2013, 09:22 AM   #3
hugger6933
I don't know if the warranty is still the same but the General used to have 3years 36k on their crates, at any GM dealer in the country although that number has shrunken by a ton in the last five years. Also you can step up from a step or two above stock with them and they can make crazy type power without much effort.
hugger6933 is offline   Reply With Quote
Old 12-26-2013, 09:57 AM   #4
70CHEVYBB
70CHEVYBB's Avatar
Crate is way cheaper than rebuilding, I sent you a p.m. on a crate motor
70CHEVYBB is offline   Reply With Quote
Old 12-26-2013, 10:01 AM   #5
msgross
msgross's Avatar
This was $1200, not sure if they still have any but it seems like a good deal
http://67-72chevytrucks.com/vboard/s...d.php?t=606983
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-26-2013, 10:23 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Nope, sale ended on the 16th They're back to $1,500.
I got mine though!
If a crate is how you think you'll want to go... add this seller/ad to your ebay profile. Free shipping, to your DOOR!, and no taxes Jegs almost always has better deals on their ebay site than store (eastwood too!) Check the ad about once a week. At least once a month or so they drop the price, usually somewhere between $1,299 and 1,399. $1,206.99 was the cheapest I'd ever seen 'em and had to jump on it.
http://www.ebay.com/itm/400444180233...84.m1423.l2649
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-26-2013, 10:54 AM   #7
midniteblues
midniteblues's Avatar
I got mine though!
i'm regretting not jumping in on one of them.....just for a spare that was a good deal.
i had bought a crate from either advance or zone back around 96-97 i paid around 8 bills for it with a core.
the jeg's deal is the cheapest i saw since that time.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-26-2013, 11:08 AM   #8
67ChevyRedneck
I did the same around 2002, I think I also paid around $800 after the core from advance. This is the motor I'm replacing. I think the same crate motor I just bought was around $1,450 even back then. I haven't run a compression test, but after 35,000 miles cylinder 3 is fouling the plug regularly and smokes a bit from that side (I run duals without a cross over). It runs like crap for the first few minutes then good after that (probably after all the oil blows/burns out of the cylinder). I consider it a lesson learned. I probably ruined that motor I learned how to install parts, HEI, tune a carb, etc on that motor. I over revved it a couple times. Overheated it a few times. Harmonic balancer went (vibrated like crazy) but still had to drive it until I had time to fix it, which then caused the seal to go, then it blew oil everywhere I figure I got my money's worth out of it. I'm giving it to a friend that has stored my fleet bed for the past few years for me as payment. He'll probably rebuild it.
Jesse James
Project "On a Dime"
Old 12-26-2013, 11:22 AM   #9
midniteblues
thats funny cause the one i had would have one crummy plug when they were changed. an it would foul if i over choked it but it always cleared once it got warm. i beat the snot outa that engine. then sold that and my 93 yamma warrior to fund the 355 in my camaro.
Old 12-26-2013, 12:21 PM   #10
A lot depends on things like intended use,overall approach to the truck. If you aren't going to be racking up many miles,I think it's cool to rebuild what came in it,just because. I need to do something with my '72 motor. Just because,I want a 383 and decided to use the original 350 in it because everything will stay original except what's inside. The vibe of the truck is "what GM coulda done"...but didn't,a '72 K3500.
Old 12-26-2013, 12:45 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
It comes down to a couple of factors.If you can do assembly yourself then a rebuild may be OK.If you can'tyou will probably have asmuch in a rebuild as a crate.Depending on the rebuild,you may or may not get a warranty.If you're looking to up the power a littleand get good driveability then either should do it.Check with the locl cruise night guys and find out what machine shops in your area are good and get some estimates.I've seen machine work cost $800 and after parts you may be on price with a crate over the rebuild.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-26-2013, 07:12 PM   #12
Heavymetl
You could always go LS. Junkyard 5.3, carb, MSD controller, and your stock TH350 bolts right up with a basic flexplate adapter. I just bought a solid complete LM7 5.3 for $550.
Heavymetl is offline   Reply With Quote
Old 12-26-2013, 08:07 PM   #13
Grumpy old man
Grumpy old man's Avatar
rebuild you know whats in it and how it was put back together stays matching.
crate motor you get someone elses core and generic assembly non matching
if you can't do it yourself let your check book decide ?
Grumpy old man is offline   Reply With Quote
Old 12-26-2013, 08:58 PM   #14
67ChevyRedneck
No. GM crate engines are brand new motors.
Jesse James
Project "On a Dime"
Old 12-26-2013, 09:15 PM   #15
Grumpy old man
i was refering to the mention of advance and jegs
Old 12-26-2013, 09:41 PM   #16
67ChevyRedneck
I bought my GM crate engine from Jegs.
Jesse James
Project "On a Dime"
Old 12-26-2013, 09:43 PM   #17
Carl Spangler
Carl Spangler's Avatar
IMO, if the motor is original it would be a travesty to pull it and put a (Mex built) crate motor in the truck. For the love of all things Chevy please rebuild the original motor.
BTW, that 40 YO seasoned block is WAY WAY better than a new block.
cheers
JohnG
Carl Spangler is offline   Reply With Quote
Old 12-27-2013, 12:44 AM   #18
The term "crate engine" is misused these days. Crate engine means 100% new assembled engine. Nothing wrong with "seasoned" blocks,cranks,etc. but that's rebuilt and what I'd call a "turnkey engine". Jegs sells GM Performance Parts "crate engines" as well as Blueprint "turnkey engines"
Old 12-27-2013, 01:35 AM   #19
Yellow72C10
As far as that goes, about 10k budget-wise. I plan on a 4 inch lift, with some 33s under her. I know that the rebuilt will be lacking in power. (180?) but I think that's the route for me, keep it original. My granddaddy would roll over in his grave if a mexi built Motor was out it in. No offense to anyone. If I did get a crate motor, i don't know what I'd do with the original? I couldn't bring myself to scrap it. Dow the road I may throw in a bigger cam and bigger heads, bump things up. Well see I reckon. Thanks for the input fellas
Old 12-27-2013, 01:43 AM   #20
Coley
Coley's Avatar
Smile Re: Rebuilt or crate?
You shouldn't have too much problem getting a fairly honest 300hp out of rebuilding your original sbc.
Just to need to choose a reasonable cam and heads. Then a few considered bolt-ons.....nothing expensive and there are lots or parts available for the upgrade.
Keep us posted on your progress.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-27-2013, 01:54 AM   #21
Yellow72C10
Coley
I think you are right. My biggest concer after that would be the transmission. I'm going to get it rebuilt, but I don't know how much a rebuilt th350 would handle
Old 12-27-2013, 08:43 AM   #22
MARKDTN
If you like original, or want to have the experience of doing it, then build yours. In dollars and cents you will be hard pressed to do it cheaper than you can buy a new crate one. Last SB engine I built (327 from '68 Camaro-bone stock) was around $1500 in parts and machine work and that was in about 2004. Now it is as good as it was new but it isn't cheap to do it right. Price the machine shop work for heads (guides, valves, springs, hardened seats, etc.- which is probably the biggest chunk), bore block, turn crank, check block, clean parts, re-size rods, press pistons, magnaflux-the whole deal-and I'll bet it is at least $1000. The kit for all the parts and gaskets and a cam kit can easily be another $500+. To me it depends on if you want to get it done quick and easy for the least $$ (crate in a weekend) or if you want to do it yourself and have the experience (build it over a month or so).
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-27-2013, 09:01 AM   #23
I can rebuild a 350 for less than a crate engine. These trucks came with plenty enough horsepower to do whatever you need to do. There was nothing inadequate about these trucks and still isn't The trucks have always been great and that hasn't changed...people have changed. A stock truck 350 could have as much as 250 hp and that's a healthy dose of power. Without going crazy (or great expense) you can build a 300 hp 350.
The TH350 is also an awesome transmission. They can go forever w/o a rebuild and they can take a whole heap of HP. We see them behind angry big blocks in drag cars.
Old 12-27-2013, 05:19 PM   #24
MARKDTN
Maybe with a rebuild, but when they do go they grenade. Eventually the front section will disintegrate if you really put the power to it. I'm not saying a TH350 is a bad trans because it is not, but it is not as strong as a TH400 and they do break.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 12-27-2013, 05:38 PM   #25
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The TH400 is a great transmission. But when stuck behind a stockish SBC, it will also rob you of about 40hp. The ol' TH350 is a great tranny, designed for the TQ curve of SBC's, and will give long life... even when you thrash on them.
I can rebuild a stock to mild 350 engine for under what I would have to pay for a crate engine. But that's me.
Also... this "numbers matching" stuff only really matters if we're talking 'vettes, Camaro's and specialty Chevelles (Like an original LS6) These trucks and the engines were a dime a dozen...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
350, 4wd, chevy, rebuild
