12-29-2013, 05:14 PM | #1 |
Suburban ride height
I'm just about to pull the trigger on some suspension parts and have a question. Can someone please tell me the stock ride height for my 72 suburban? I think a PO might have heated up the springs to lower it. I have a set of 20" boss 338 on it and the distance from the top of the tire to the fender is 5 1/2" front and rear.
I am looking to keep it level but about 3" lower. Thanks |
12-29-2013, 06:11 PM | #2 |
Re: Suburban ride height
It's really hard to judge a lowering job that was done by a P.O. If I was you, I would look at the photos on here. There is a ton to look at. Find what tickles your fancy and go from there. There is a 2wd burb thread around here somewhere that could point you in the right direction.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
12-29-2013, 06:13 PM | #3 |
12-29-2013, 07:38 PM | #4 |
Oh I've seen it. About 3 times a day!!! I'm looking for some stock measurements so I know where I'm at and can better judge where I want to be and what parts will get me there
12-31-2013, 02:49 PM | #5 |
Has anyone used truck rear coil springs to lower a suburban? If I do can I expect more drop than advertised? Looking to get something from classic industries while they have it on sale.
12-31-2013, 07:52 PM | #6 | |
The Older Generation
I would think the springs would lower the Burb more than it would a pickup because of the weight difference but we will have to see if someone who has tried it chimes in... LockDoc
01-01-2014, 02:15 PM | #7 |
Looks like the original ground clearance info is in this document: http://www.gmheritagecenter.com/docs...t-Suburban.pdf You have to scroll down when it opens... LockDoc
01-01-2014, 04:49 PM | #8 |
Lockdoc, thanks a ton. That's exactly what I needed along with a ton more info. Also while researching and second guessing myself I found an awesome deal on the parts on the parts board! Win Win!
Also thanks for you sticky on the hatch lock. It saved me a lot go aggravation. |
01-01-2014, 10:42 PM | #9 | |
No problem. That's what were all here for, to help each other out. Now you will be able to pass the info on to someone else when they need it... LockDoc
