01-18-2014, 10:54 PM | #1 |
My 4/6" ECE lowering install thread - 72 Shorty
I ordered the ECE 4/6 lowering kit before I even picked up my 72 Super Cheyenne 5 months ago in California and drove it back to Houston with my Canadian buddy (thread: http://67-72chevytrucks.com/vboard/s...d.php?t=595586). Now, I'm finally getting around to doing the install.
I also ordered a ECE heavy duty front sway bar with poly bushings. I'll be installing a poly transmission mount too, since the stock one is dead. One request I have from those who've installed this is a list of required tools to do the install. My tool inventory is building, so I'll plan to run over to home depot whenever I need something. If people who've done this can suggest required tools, it'll make fewer trips for me. The truck's history is not documented but it looks to have been lowered somewhat already. My measurements to the fender before installing the ECE kit are: Front' L 29-1/8" R 29-1/2" Rear L 31" R 31.5" Current height: Up in the air this evening. There's a jack at the rear too. I'll update this thread with progress and probably questions too. |
01-18-2014, 11:40 PM | #2 |
Re: My 4/6" ECE lowering install thread - 72 Shorty
I like allot!
01-18-2014, 11:59 PM | #3 |
Dan Johnston
I am following this thread... This is what I am putting on my 67...
01-19-2014, 12:42 AM | #4 |
x2
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-19-2014, 02:01 AM | #5 |
Very nice truck! Simple hand tools should get the job done. A nice 1/2" ratchet and some wrenches, maybe also a hammer and pry bar. You also have to bust some rivets to get the sway bar brackets on
01-19-2014, 04:15 AM | #6 |
Nice truck indeed. The underneath looks clean. Lay large sheets of cardboard to work off of and catch dirt that comes loose from the disassembly. Have some chassis paint or equivalent for detailing those areas you will address. Add a rear sway later, they turn these trucks into go kart's.
01-19-2014, 04:27 AM | #7 |
70+ ( Old Skool Club )
Subscribed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-19-2014, 08:22 AM | #8 |
a 3/4" socket set will help,lotsa lube,wheel bearing grease, grease gun,a good bfh,a good sharp cold chisel,a long punch,drill & bits,a good pair of heavy gloves.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-19-2014, 08:37 AM | #9 |
good looking truck man. as far as tools find a harbor freight close by and grab a socket set, ratchet wrenches, mini sledge, and a pry bar. you'll save at least twice as much as home depot and the hand tools have a lifetime warranty.
01-19-2014, 09:42 AM | #10 |
Dan Johnston
01-19-2014, 09:52 AM | #11 |
Loves all GMC trucks
Get some rust penetrant and spray every bolt your going to touch before you get started several times before you get it torn down. It will aid you...
01-19-2014, 10:23 AM | #12 |
Tot Roddin'
You'll love the new kit.
Also... You might have to rerun the exhaust. Just a heads up.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-19-2014, 11:47 AM | #13 |
how tall are your rear springs?
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
01-19-2014, 11:54 AM | #14 |
Subscribed as well. That is exactly what I plan to do to my '69. I will be adding 4 wheel discs at the same time.
01-19-2014, 01:46 PM | #15 |
Subscribed!
01-19-2014, 01:59 PM | #16 |
Thanks for the tool tips. I made a trip to harbor freight and will be getting started this evening.
01-19-2014, 06:11 PM | #17 |
Watch out for your cornhole !
The hardest part of the whole job is removing the four rivets that hold the stock upper shock mounts in place.
01-19-2014, 10:35 PM | #18 |
Subscribing, loved this truck since your "drive home with pics" thread. Looking forward to the results!
01-19-2014, 11:38 PM | #19 | |
Stock upper rear shock mount. Punched for pilot holes. killing 3 sizes of drill bits to get this far. Now the hard part, wiggling the hell out of it. My chisel and mini sledge were not effective. I just about cried with joy when the second rivet came off. Better drill bits are in order. I underbody sprayed the scuffs made by the removal to avoid rust later. |
01-20-2014, 12:04 AM | #20 |
67-72 parts collector,…
Everybody tries to remove those shock mounts in one piece.
I lop off the ears and grind the rivet heads off. They go in the trash anyway. Super fast.
01-20-2014, 11:08 AM | #21 |
This^ Nice Truck
Evaded
If I see a Zombie.. Im runnin it over with my Truck. |
01-20-2014, 11:48 AM | #22 |
Tot Roddin'
Keith is right. When he was down to help install the drop kit on my 69 that was the trick.
01-20-2014, 04:32 PM | #23 |
I'm following this for when I put the same kit in my 72
If we learn from our mistakes I should be a genius by now.... |
01-20-2014, 04:38 PM | #24 |
///Relaxed Atmosphere
its a nice kit you will be happy with it
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
01-20-2014, 06:37 PM | #25 |
Man, I didn't know about that... I have a blazer tank back there... I don't really want to make sparks.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
