Old 02-26-2014, 01:41 AM   #1
72MARIO
72MARIO's Avatar
Accuair E level and Ride Tech Big Red valve ?
I currently have air ride technologies E2 system with the big red valve reduced to run 1/4" lines. I am looking at buying the Accuair E level system. I cant drive this truck another season having to break out the tape measure every time I want to get on the hwy for a long drive and set the ride height bang on.
There a harness available to allow the big red valve to plug and play with the accu air system. Is that a good Idea ? or is there a advantage to using the VU4 valve ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-26-2014, 07:47 AM   #2
mac808
mac808's Avatar
Re: Accuair E level and Ride Tech Big Red valve ?
From Accuairs FAQ's:
The benefit to using the AccuAir VU4 Valves with the e-Level system is the ease of wiring because the harness is plug’n’play for this case. If you are using other manufacturer’s valves, you will have to make sure to connect the solenoid drive wires from the e-Level in the correct orientation to your valves. (We do offer adapter harnesses for some other manufacturer’s valves, but in all cases our harnesses are color coded for easy hookup.
mac808 is offline   Reply With Quote
Old 02-26-2014, 07:48 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Contact Accuair.
http://www.accuair.com/intro
Or add their e-level system to your big red valves,...
Q: Will the e-Level System work with other manufacturer’s solenoid valves?
A: Yes, our system will work with any 12-volt solenoid valves on the market. The benefit to using the AccuAir VU4 Valves with the e-Level system is the ease of wiring because the harness is plug’n’play for this case. If you are using other manufacturer’s valves, you will have to make sure to connect the solenoid drive wires from the e-Level in the correct orientation to your valves. (We do offer adapter harnesses for some other manufacturer’s valves, but in all cases our harnesses are color coded for easy hookup.
Keith
Convert to disc brakes.
Old 02-26-2014, 08:29 AM   #4
72MARIO
72MARIO's Avatar
Thanks ! I guess will just use my valve block. I like the design of the VU4 but its mounted inside the rear 1/4 of my suburban and will never see it anyways..
I love the post minutes apart ! I didn't think to look at there FAQ's
2005 TAHOE DD
