Old 05-21-2014, 12:24 PM   #1
young.gun
Aftermarket C20 brakes?
So guys i need to know who makes aftermarket 1970 C20 brakes or any brake parts for that matter, id prefer to convert to a 4 wheel disc or rebuilt drum system with drilled and slotted rotors in the front but i have yet to find a company that makes either of those for the 8 lug trucks?
young.gun is offline   Reply With Quote
Old 05-21-2014, 06:03 PM   #2
SCOTI
SCOTI's Avatar
Re: Aftermarket C20 brakes?
Drilled & slotted for a HD truck? Why?
If you desire increased brake performance, solid rotors that are a larger diameter would offer greater contact area of the friction surface (if they were available). 4whl disc brakes is possible using a later model rear end that's already set-up for discs or a conversion kit that utilizes C20/30 (single wheel) brake hats for a late model & older Cadillac rear calipers (w/e-brake) or C10 front calipers (no e-brake).
http://diy4x.com/cart/index.php?rout...tegory&path=37
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2014, 01:09 AM   #3
tinydb84
tinydb84's Avatar
You can use the stock brakes from the front wheels of a 4wd.
http://www.pirate4x4.com/tech/billav...b_disc_brakes/
David
Instagram: myfabguy
3/4 ton, 8 lug, brakes, c20
