Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 06-26-2014, 08:37 AM   #1
Essayon
88 v30
So it seems that these trucks are sort of hard to find. I hope that the parts aren't. I got into it without doing much research because it is just too cool.
http://67-72chevytrucks.com/vboard/a...1&d=1403785950
Essayon is offline   Reply With Quote
Old 06-26-2014, 08:39 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 88 v30
There should be nothing on that truck that's too big of a challenge to find. There's a pile of 88-91 Suburbans out there just waiting to give up interior, dash, drivetrain and front sheetmetal if you wan't to go that route.
Old 06-26-2014, 11:23 AM   #3
Essayon
Re: 88 v30
If you go on autotrader/ebay and search for 1988 Chevy truck four door nothing pops up. I did see that there are a lot of yards though with parts however in my neck of the woods as soon as a Chevy truck hits the "you pull it yards" they are stripped clean. Like you said though I don't see it to be a problem now though.
I need to get new door gaskets...any suggestions?
Old 06-26-2014, 11:48 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
Re: 88 v30
type in 87. You will get a lot more results. Almost all the parts will be the same. They kept the crew cab going until 91, even when the reg/ext cabs changed in 88.
95 S_Trucker is offline   Reply With Quote
Old 06-26-2014, 01:13 PM   #5
Tx Firefighter
Re: 88 v30
True.
Erase the number 88 from your memory and replace it with 87. Your options will greatly expand.
I still stand by my 88-91 Suburban suggestion. A gigantic majority of them were power window/lock trucks and most Suburbans are pampered condition compared to four door work trucks. The doors alone make parting out a 'burb a worthwhile avenue to take. You get doors and seats and dash and all front sheetmetal.
Old 06-26-2014, 03:53 PM   #6
Essayon
Re: 88 v30
So the plan is to bedliner the bed and the cab.
I removed the rubber mat and tore out the installation but found caulking that seems to separate sections of the floor. Should I remove this caulking or put the bedliner over it? I will have pics of all this when I get home.
Old 06-30-2014, 11:10 AM   #7
Essayon
Re: 88 v30
I've got er primed last night at first coat of bed liner in!
Old 06-30-2014, 02:21 PM   #8
Essayon
Re: 88 v30
Will these fit?
http://www.brotherstrucks.com/prodin...number=TRWF287
Old 06-30-2014, 02:27 PM   #9
Tx Firefighter
Re: 88 v30
Assuming your truck is a 2wd, they'd fit. But you take a screwing buying stuff like that from Borthers. Mechanical parts are best bought at parts suppliers not specialty shops like a Brothers.
I just looked up coil springs at Rockauto and found a good selection for 90-95 dollars. That's real savings there.
Old 06-30-2014, 02:45 PM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 88 v30
Door seals are easy to get. There are many places that have them. They are the same seals for a Crew Cab from 81-91 and the Suburban those same years.
Get a LMC Catalog for the 73-87 trucks and suburbans. They will have everything you need in it. Take the time to search on the net for deals. LMC can have some of the higher prices. Try places like RockAuto.com for the seals.
I looked them up and pasted them here:
1988 GMC V3500 PICKUP 5.7L 350cid V8 : Body-Exterior : Door Seal / Weatherstrip
VARIOUS MFR Part # GM1390101 {#15522764}
R/V; body mounted; Left Front door weatherstrip
R/V; body mounted; Right Front door weatherstrip
$13.52
VARIOUS MFR Part # GM1390104 {#15014399, 15758703}
door surround; extended cab; w/o access door; Right Front door weatherstrip
door surround; std cab/crew cab; Right Front door weatherstrip
$13.99
FAIRCHILD Part # G3009 {Click Info Link for Alternate/OEM Part Numbers15758703, 15766539, 15956393, 15956394, 15973659, GM1390104, GM1590111}
Door Seal; OldStyle; Location: On Body; Front Right
Door Seal; OldStyle; Location: On Body; Front Left
Door Seal; OldStyle; Location: On Body; Rear Right
Door Seal; OldStyle; Location: On Body; Rear Left
$16.85
FAIRCHILD Part # KG3009 {#15758703, 15956393, 15956394} Components: G3009*2
Door Seal Kit; On Body; Old Style; Front Right
Door Seal Kit; On Body; Old Style; Rear Right
Door Seal Kit; On Body; Old Style; Front Left
Door Seal Kit; On Body; Old Style; Rear Left
$28.79
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-30-2014, 03:33 PM   #11
Essayon
Re: 88 v30
I hope one day I will be able to return the favor thanks guys!
Old 06-30-2014, 04:01 PM   #12
Essayon
Re: 88 v30
Hey Kevin what's that link to the coil springs at rock auto or the part #?
Old 06-30-2014, 04:05 PM   #13
Tx Firefighter
Re: 88 v30
First off, if your truck is a 2wd, it's an R30, not a V30. That's a critical thing to remember when shopping for parts.
I went to Rockauto and catalogued an 87 R30 truck when I looked them up. You'll go down to suspension and then choose coil springs, and there's a pile of them to select from. Just make sure you read each part description carefully because some are for light suspension, some heavy suspension, some dual wheels, etc. I'd assume you're shooting for heavy duty on your truck so focus on the F42 suspension or whatever it is.
If you're wanting uber heavy duty, the Moog part with F42 suspension and the "super duty" option looks good.
Also , here is my discount code at Rockauto. Use it as much as you like. 2316502721314303
Old 06-30-2014, 04:11 PM   #14
Essayon
88 r30
Got it! R30 it is...you've made my day!
Old 06-30-2014, 04:41 PM   #15
Tx Firefighter
Re: 88 v30
Anytime man.
Old 07-01-2014, 09:57 AM   #16
Essayon
Re: 88 v30
Phase one complete on to dents!
