06-28-2014, 12:58 PM | #1 |
leaf spring swb fleet sport bumper bracket pics
I need pics of the brackets installed on a swb fleet leaf spring truck.thanks
I have the brackets can't figure out how they mount I've read about 6 threads on this but all pics are gone. |
06-28-2014, 01:16 PM | #2 |
67-72 parts collector,…
Re: leaf spring swb fleet sport bumper bracket pics
Does this help?
06-28-2014, 01:19 PM | #3 |
thanks but no I have these brackets.
06-28-2014, 01:22 PM | #4 |
They attach the same way.
Long bracket on the inside of the frame. They're just extended to reach aound the leaf spring hanger.
06-28-2014, 01:30 PM | #5 |
here is mine when the front hole lines up theres no hole for the rear
06-28-2014, 01:33 PM | #6 |
the frame
06-28-2014, 02:12 PM | #7 |
Is that bracket for the other side?
You can identify the top side of the bracket,... because it has a hole in it for the gravel guard to bolt to.
06-28-2014, 02:16 PM | #8 |
yes the gravel guard hole is on top
06-28-2014, 02:22 PM | #9 |
confused by this pic bracket seems upside-down
06-28-2014, 02:25 PM | #10 |
Just found this thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=213260
06-28-2014, 02:33 PM | #11 | |
06-28-2014, 02:38 PM | #12 |
this is an original coil spring bracket
06-30-2014, 02:34 PM | #13 |
Update for those with holes in your frame like mine in post #6 You might try coil spring brackets they line up a better. Check pics the rear hole is right on the the leaf spring hanger.
06-30-2014, 02:42 PM | #14 |
coil spring bracket
