Old 07-31-2014, 10:22 AM   #1
kentukblue
Another suspension thread: IFS and 4-link questions
We have pretty much narrowed down our our 51' in the chassis dept to an IFS and 4-link rear coilover setup. Prevailing opinions have led us down the road of spending a few more dollars over the basic MustangII front parts and rear leaf spring kit, especially given we are gonna have 345hp, 380 ft out of a 6.0 LQ9 hitting the ground.
Were sticking with the original frame and i would like the least amount of alteration to it as possible.
1. We have narrowed our choices down to TCI Coil-over IFS and coil-over 4 link rear or NO LIMIT Road Glide IFS coil-over and Fat-bar 4 link rear coilover. Any general opinion on pros/cons to either? Adjustablility?
2. How low can we get with a 4 link rear without altering/notching the frame?
3. I see 4 links setup inside and outside the frame....some bolt in and some weld in. Any better than the rest?
4. Have we overlooked a better* choice for suspension kits? (BETTER = quality parts, geometry/fit, ease of instillation, adjustability)
kentukblue is offline   Reply With Quote
Old 07-31-2014, 01:30 PM   #2
Advanced Design
Advanced Design's Avatar
Re: Another suspension thread: IFS and 4-link questions
Kentuckblue,
Sounds like you have a great project!
On my black truck we used a triangulated four link fabricated from suicidedoorsdotcom components and it worked well.
The 48 Suburban we are building now has a parallel four link with the link control arms to the outside of the frame. They do interfere with the rear running board mount so I will have to relocate that forward.
Neither truck has a kick up, just a C notch in the frame. The truck is aired out and the Suburban is at approximate ride height.
Advanced Design is offline   Reply With Quote
Old 08-01-2014, 06:47 PM   #3
kentukblue
Any particular recommendations for rear axle besides the Explorer 8.8? Would like to have 5x4.75 with disc brakes and posi.
Old 08-02-2014, 03:46 PM   #4
aknovaman
This will help you identify the correct 8.8 inch rear to get for your truck.
http://www.therangerstation.com/tech...le_codes.shtml
I got mine for $175 and $60 for a second short axel as I am narrowing it to tuck in the tires. For the price you just can't beat it plus they are indestructible.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 08-04-2014, 05:01 PM   #5
Scottshotrods
Here is one more to look at for your truck www.scottshotrods.com we have you covered front to back and any other parts you might need to complete the build on your truck.
Let us know if you have any questions at all?
scotts@scottshotrods.com
Justin
Scottshotrods is offline   Reply With Quote
Old 08-09-2014, 02:34 PM   #6
1-ton of fun
polishing a turd
1-ton of fun's Avatar
I'm using the no limit fat bar 4 link in the rear, but with different coil over brackets and an adjustable panhard bar mount. I'm very pleased with the kit overall. I think it COULD be bolted on to the frame but I welded it
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 08-09-2014, 05:55 PM   #7
Sethmark
I'm using the heidt ifs and a combo of Posies 3" drop leaves and 2" blocks. I'd like it lower. The truck sits dead level and is about 5" of total drop. I could do a 2" drop spindle up front, but I believe that more than an inch more in the the rear would need a notch.
Fwiw, I'm running a 350 with a decent cam and intake and a th350 behind it. No problem with axle wrap.
Sethmark is offline   Reply With Quote
3100, 4-link, ifs, ls swap, suspension
