![]() Join Date: Sep 2007
1967 squirrel cage
is a 67 c10 squirrel-cage different from the others in this era? I pulled off my heater housing from the firewall and discovered a huge mouses nest in all cavities. Its all cleaned up but now I need to replace the squirrel cage as the mouse was chewing on it and ate it all up. This one seems to be a little bit smaller though. It measures 2 and three quarter inches top to bottom
1967custom |
![]() Join Date: May 2010
Re: 1967 squirrel cage
I don't know if the squirrel cages were common across other GM models. I only know what's original to my 69 with A/C. If a mouse damaged yours by chewing on it, I'd say it's incorrect since mine is made of steel. As I recall, it's also much more than 2-3/4" diameter... more like 5"or 6". It just fits through the hole in the box.
The Older Generation
From what I have seen '67-'72 non A/C are all the same size. Most of them are plastic but I have seen a few metal ones. Not familiar with the A/C ones.... LockDoc
Its plastic. I foind the same exact one on a 68 yesrerday.
Did you gus know the motors have date of manufacture on them?
1967custom |
#5 | |
Never paid any attention to that but the motors themselves are the same up into the late '70's. LockDoc
Yeah mine says mfg. 03-1967. Cool huh? Good to know for guys going date correct on their trucks
1967custom |
![]() Join Date: Sep 2005
you can have them rebulit
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
You can? I bet a small engine shop could. The motor works well. Just the cage was all chewed up
1967custom |
![]() Join Date: Nov 2001
It's seems a common place for mice to make a nest. Mine was way so bad it smelled and rotted the interior air box also chewed up the cage. I had to clean and replaced everything. If I recall the cage was 5 to 6 inches round.
It is to my understanding that heater cab squirrel cages are plastic and AC cabs are steel
Yeah that makes sense. Ive never had an ac cab though
1967custom |
