![]() Join Date: Jan 2013
Radiator mount help please
Installing a 4 core OReilly Radiator and it's sitting about 3/4 inch high for the upper mounts to be able to bolt to the support. I can't see how it could go down any further. Frustrated.
Re: Radiator mount help please
jdw; heres a idea. its up to you. I know the original rubber mounts are rather " thick" so maybe one or more layers of inner tube cut to to fit might do it. Sounds kinda cheezie or redneck but sometimes those ideas work best.Use enough layers to keep the radiator from rattling around. If it works let us know how it does. Good luck.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
![]() Join Date: Jun 2012
I had to trim my lower mounts for my Be-Cool to sit low enough for the top mounts to work and to keep the shroud in the right place
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
Are you using 4 core cushions?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
To get my 4 core from autozone to sit right I had to change my lower cushions and retainer to the larger ones.
Well, I ordered the 4 core retainers and cushions from LMC, but even if they were made right I guess that doesn't mean that's what I got. I'm replacing the radiator (O'Reilly), the mounts and fan shroud (LMC), the fan, and fan clutch all at the same time so it's getting hard to figure out what's off.
It fits right in with no cushions, but that's crummy. And yeah, I guess I can use bike tire tubes. I just didn't want to. Here's some pictures |
Also, does this look right?
![]() ![]() Join Date: Sep 2008
If you go ahead and bolt it down carefully, I think you will be surprised how it will "settle in". You may have to put some weight on the brackets as you go. The new rubber will compress.
BTW does you radiator have the heater hose fitting? Larry
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
try what vidman suggested; trim them down. I might suggest a belt sander. A little bit at a time. watch your knuckles though.
I am a Referee of life.
That looks somewhat like mine did when I swapped. The rad didn't just fit down into the rubber, it had to be pressed in with the clamps. I was swaeting bullets but it worked out. I did make sure everything lined up right before I started cranking it down.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jul 2001
I may be looking at it wrong but in your last pic it would seem you are still using the original 2 & 3 core lower radiator mounts? Those need to be changed as the 4 core mount is longer to account for the extra core. My guess is the radiator is sitting on top of the lower cushion or mount and not saddled in as it needs to be. That being said, you will need to trim or notch the radiator support at the engine side where the lower mount sits for the four core seats. I used 4 upper mounts when I swapped in my 4 core to my '71 4x4. Used the two 4 core upper mounts as usual and then drilled the saddle portion off two upper mounts, used them as lower mounts and then made the notch to the radiator support as I mentioned above. It makes sense when you try to mate the 4 core mount in postion to the support. I used self tapping low head sheet metal screws to hold the saddle in place. Also may need to get the 4 core shroud clips that hold the shroud tight at the low end.
Hope that helps, long winded I know but that looks to me to be the problem. Good luck. ![]()
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#13 |
Those are the old mounts that are in there, but they are the same size as the new 4 core I ordered so I left them in there. They seem to sit just fine with either set of rubber, just lower with the old. I'll check 'em out again outside the truck just to make sure. The upper, were obviously for the 2 core as they are quite a bit shorter. I'm guessing at some time in the last 40 or so years someone just found it easier (lazier) to leave the 4 core mounts in the bottom.
Thanks for all the replies, I'll try trimming and crushing next Monday when I get back to it. |
#14 |
Is this a '67-'68, if it is the lip on the core support, under the rad. has to be cut away, at least it did on mine, for clearance
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#15 |
I agree with Larry and PanelDeland, that is normal and will tighten down just right, nice and snug.
#16 |
I just did this yesterday. I had to cut the lower mounts towards the engine off and also the tops were cut flush with the rest of the mount. I left the pads alone and it fits nice. I'm working on the shroud today to see what I have to do to make it fit
#17 |
I am trying to mount my radiator as well. It's an original 2 core unit and the rubber cushions are gone. The lower clam shells are rusted out. I bought some prothane inserts that dont even come close to fitting. They actually sit lower than the shells when inserted so they would be pointless.
Anybody have any part numbers for the correct upper and lower inserts and or metal clam shells for a 2 core radiator? Thanks! |
#18 | |
![]() Join Date: Jul 2015
It does take a little fudging around to get them to settle in. |
#19 |
I have the exact same problem. I have decided to make "spacers" out of PVC tubing and use longer bolts. I'll have to drill one hole in my (new to me) core support as one bracket won't line up.
If anyone puts in 4 row lower retainer brackets, don't forget to bend the lip down there down to make room for the bracket. I had to do this but I saw a pic on here where another member had done it. He suggested a cresent wrench, it worked great for me. I dremeled out the rivets that hold on each retainer and replaced with a machine screw and lock nut. That way I can remove those 4 row retainers and go to a 3 row. Originally my truck had a 2 row radiator that sat on the core support itself (no brackets at all) on just a thin strip of rubber. That was factory. Now I've tested it with 3 row lowers and my original radiator sits perfect for the upper brackets. Strange. I am not using my original radiator though but a 3 row aluminum job from KKS. |
#20 |
I used a bench grinder to trim mine down. Without grinding them had the same problem as the OP.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#21 | |
The Older Generation
Here is a post by member "67 cst swb" about radiators: Quote:
#22 |
If I had to do it over, I'd get my original radiator recored. I plan to eventually. In the meantime, it's going to be the KSS all aluminum radiator.
I am using 4 row brackets on the bottom and 3 row brackets on the top. That's what fits best for it. Last edited by In The Ten Ring; 07-23-2017 at 01:39 PM. |
#23 |
So does anybody make 3 row mounts? I can't seem to find any that are broken down for radiator size. I bought prothane inserts for the 67-72 truck and they won't work. Maybe they are 4 row inserts and since I have 3 row inserts and radiator they are not correct?
I also need the bottom shells since mine are rusted out. Thanks! |
#24 |
I found the KSS website, but no pricing. Who sells KSS radiators?
#25 | |
I couldn't drill out the rivets holding in my originals, I had to grind off the rivets from underneath the radiator core support with a Dremel Tool and punch those out with a hammer and punch (core support off truck for that). I found some originals on the parts forum and hope to use those when I go back to my OEM radiator. |
