Old 10-25-2014, 12:19 AM   #1
suttonca
Controls arms
I have a 1984 chevrolet shortbox with a 5/6 drop. drop spindles in the front and c-notched in the rear. The problem I am finding is that the front control arms are just to low causing them to rub on pavement all the time. Is there someone that makes different control arms with more clearance or what is everyone doing to rectify this issue?
suttonca is offline   Reply With Quote
Old 10-25-2014, 09:49 AM   #2
siroadrnr
siroadrnr's Avatar
Re: Controls arms
aftermarket crossmembers and control arms. Researching which for my truck now.
"Its never too late to have a happy childhood."
70 Roadrunner,.. 79 Blazer, ..85 Harley bobber,.. 97 GMC Suburban Diesel,.. 99 Sierra, ..06 Ducati Monster Dark, ..07 Silverado ,.. 11 Audi A4
siroadrnr is offline   Reply With Quote
Old 10-25-2014, 10:59 AM   #3
SCOTI
SCOTI's Avatar
Re: Controls arms
Some lower arms have a 'slimmer' profile that possibly provide a bit more clearance but the pivot points where they attach to the x-member are still the lowest point. The only cure for that is raising the x-member in relation to the frame rail:
  • Notched/pancaked OE x-member (up to 1.5")
  • Cutting & raising the rails themselves (frame 'Z' 1-3")
  • Swapping in an aftermarket x-member built specifically to correct this issue (3").
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2014, 01:57 PM   #4
tinydb84
tinydb84's Avatar
Re: Controls arms
Taller tires might be an option too. If you are planning on new wheels just go with tires that are at least 2-4 inches taller overall.
David
Instagram: myfabguy
Old 10-25-2014, 03:50 PM   #5
SCOTI
SCOTI's Avatar
Re: Controls arms
Going taller negates the installed drop as it raises the vehicle. What size are the current wheels tires?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-25-2014, 03:58 PM   #6
tinydb84
tinydb84's Avatar
Re: Controls arms
The truck would still lowered but just sitting a bit higher due to the wheels.
If he is running 26'' wheels I dont think it would loose the lowered look by going to 28-29'' wheels. It may even look better by closing up some of the fender gap.
Do you have any pics?
David
Instagram: myfabguy
Old 10-25-2014, 06:52 PM   #7
suttonca
Re: Controls arms
siroadrnr, let me know what u decide to go with!!
As for taller tires, I am only 2" from the top of tire to the inner fender, wouldnt want to get any closer!! I have 18" wheels and 225/45 tires
Old 10-25-2014, 10:05 PM   #8
suttonca
Re: Controls arms
SCOTI, who makes the aftermarket kit?
Old 10-25-2014, 10:15 PM   #9
tinydb84
tinydb84's Avatar
Re: Controls arms
Nice truck. Yeah going to have to do something with that space.
Crossmembers: Porterbuilt or Scott's. They are a bit pricey.
David
Instagram: myfabguy
Old 10-26-2014, 08:01 AM   #10
jjzepplin
jjzepplin's Avatar
Re: Controls arms
Looks like you have already hit a few things. Nice truck!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-27-2014, 08:33 PM   #11
suttonca
Re: Controls arms
So, I was thinking about ordering:
http://www.summitracing.com/int/part...olet/model/c10
Anybody tried them? the one review on line says the stock sway bar will not fit into them so he has to upgrade sway bar also. I realize that my cross member sits fairly low as mentioned in earlier post but I'm thinking with these at least my control arms wont be way lower than the cross member, I dont seem to hit the cross member to much but as u can see in the pictures I sure have hit my control arms!!
TIA!!
Old 10-28-2014, 10:58 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Controls arms
There is nothing wrong with those control arms you linked, but dont expect much additional clearance. You say that you have a a 5/6 drop. How did you acquire that in the front? Your springs may be to soft causing you to scrape. Have you updated your shocks? Relocating the upper shock mount will allow you to run a longer shock and may prevent this as well.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-28-2014, 04:41 PM   #13
NEWFISHER
NEWFISHER's Avatar
Re: Controls arms
Originally Posted by n2trux View Post
there is nothing wrong with those control arms you linked, but dont expect much additional clearance. You say that you have a a 5/6 drop. How did you acquire that in the front? Your springs may be to soft causing you to scrape. Have you updated your shocks? Relocating the upper shock mount will allow you to run a longer shock and may prevent this as well.
+1
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-29-2014, 04:11 PM   #14
badchevy
Re: Controls arms
The roads in your area must be pretty bad. My truck is lowered a little more than yours and although I have scraped my control arms, I haven't beaten them up as you have. I'm running 245/60/15s on my truck. Here is a pic of my truck's control arms.
badchevy is offline   Reply With Quote
Old 10-29-2014, 06:10 PM   #15
SCOTI
SCOTI's Avatar
Re: Controls arms
Shocks.
Shock quality.
Spring rate.
Bump stops (height or lack of).
OD of front tires.
All these factors are contributors of "if contact is made, how destructive will it be".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-30-2014, 07:12 PM   #16
suttonca
Re: Controls arms
To be honest, I'm not sure how that was exactly aquired as I bought the truck that way and thatsb just what he told me was in it. Yeh, I'm guessing updating my shocks and springs will make a huge difference. The previous owner also cut off the stoppers and removed the sway bar which might also make a difference I am assuming
Old 10-31-2014, 09:56 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Controls arms
I would start with a proper assessment of what you have before replacing the A-arms.
How is your ride in general? Is it soft and bouncy, or firm or harsh? Verify that the spindles are dropped. Look at the coils to determine if they have been cut, or possibly heated. Look at the shocks to see if they show signs of leaking.
Regardless, of all that I would replace the sway bar. That won't prevent you from scraping, but it will improve the handling dramatically.
Articles-
"Refining Sierra"
Old 11-02-2014, 07:03 PM   #18
PanteraRazorback
PanteraRazorback's Avatar
Re: Controls arms
Michigan metal works makes some nice looking arms for a good price
Build Thread: 71 SWB Slammed-Shaved-6.0
PanteraRazorback is offline   Reply With Quote
Old 04-21-2016, 12:43 PM   #19
suttonca
Re: Controls arms
Well I finally decided to do some work to the truck, got sick of bottoming out all over town. Put stock height springs, new shocks, used lower control arms with all new bushings.
Definitely a huge difference although I think it might be to much for the front but now to work on bringing the rear up. Thinking I am going to try a set of lift shackles. I have a flipped axle, the mounts were cut off and welded back on so I really wasn't wanting to reverse it. Any thoughts or ideas that u might have done or seen for this?
Old 04-21-2016, 01:47 PM   #20
R.S.S.
R.S.S.'s Avatar
Re: Controls arms
Why not just pancake your cross member? That way you could still be as low as you were but you would gain the extra 1.5" in clearance.
R.S.S. is offline   Reply With Quote
Old 04-21-2016, 02:53 PM   #21
suttonca
Re: Controls arms
I cant say I have ever heard about pancaking the cross member, what does that involve? I would love more details if possible!!!
Old 04-21-2016, 04:29 PM   #22
R.S.S.
R.S.S.'s Avatar
Re: Controls arms
Here is a pic of one that I was doing for a 65 but it's the same process from 60-87. You section a portion out so that the crossmember physically moves up which will lower your truck allowing you to run taller springs for the same amount of drop. for example lets say you had 3" springs originally. if you sectioned 1" out you would only need 2 inch springs to achieve the same look and you would gain ground clearance.
Old 04-21-2016, 07:58 PM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Controls arms
I'm pretty low on tall 15's, and my control arms will hit first....better than my oil pan.
I just went down I65 across the Bridge at Lexington and hit that 2" whoop in the pavement a few times at 70. Smoothed the lip right out
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
