Old 12-11-2014, 07:24 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
73-87 steering gear upgrade
I am looking to upgrade my power steering gear box with a good unit, but i have read of many different options. which is best for my application?
In Hot Rod i found an archive of someone using a saginaw 800 steering gear, i cant seem to find it for sale. Or I dont know what year/model had the saginaw 800 -Link below-
http://www.hotrod.com/how-to/chassis...olet-cheyenne/
is the saginaw 800 the best bet? what other options are out there for these trucks? and of course what is the most economical since i am on a budget.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 12-11-2014, 09:03 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: 73-87 steering gear upgrade
Is that a variable ratio box, or fast ratio(2 3/4-3 turns , lock to lock)? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-11-2014, 11:40 PM   #3
clinebarger
Trucks use a 700 series Saginaw box, 800 series are for passenger cars.
Both are good boxes that can be built with different ratio's.
A quality rebuilt gear box, New Rag-Joint, And frame bracing works wonders on square body trucks.
Lee's Manufacturing Builds quality boxes
clinebarger is offline   Reply With Quote
Old 12-12-2014, 11:25 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
ahh thank you clinebarger! from what I read in hot rod the saginaw 800 is a quick steer unit, but apparently either box can be rebuilt to either ratio.
I have looked at the stock replacements on rock auto, since i am working with limited funds, I see this listed as the favorite power gear of the group:
LARES Part # 1262 More Info Power Gear; Reman One of our most popular parts. Works w/ Lares Steering Coupling Assembly 200
so is this a 700 or 800? when i click on more info it tells me about LARES which i looked up separately and seems like a decent company. and with a price of $130 for a re-manufactured gear.
Savannah, Georgia
Old 12-12-2014, 11:30 AM   #5
bucannon
Salty Sailor
bucannon's Avatar
I would love to do some frame bracing since i run 35 inch tires! but most of the bolt on brace kits i have seen are very pricey. anyone know of any for a fair price?
I have also gone to the HELP section of my local autoparts store and picked up a replacement rag joint, have not put it in since i cant get any bolts loose on the damn thing...
I have heard of people using a steering column from a Jeep Cherokee that has a U-joint instead of a rag joint, I might do that swap. apparently it is bolt in!
Savannah, Georgia
Old 12-12-2014, 10:49 PM   #6
clinebarger
With 35's, Your #1 concern should be bracing the frame.
Old 12-16-2014, 03:53 PM   #7
bucannon
Salty Sailor
bucannon's Avatar
Question Re: 73-87 steering gear upgrade
what vendors sell bracing kits?
I dont have a welder so Im guessing a bolt on brace would be best for my application.
Savannah, Georgia
Old 12-16-2014, 08:37 PM   #8
clinebarger
I have always fabricated my own, I wasn't aware bolt-on kits existed.
Old 12-16-2014, 08:49 PM   #9
tjsblazer
tjsblazer's Avatar
Off Road Design. See link
http://offroaddesign.com/catalog/steeringkit.htm
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
bucannon, gear, saginaw 800, steering
