Old 12-16-2014, 02:29 PM   #1
Scottsdalenstein78
Hydroboost question
I'm currently in the process of swapping an 04 lq4 into my 78 4x4
I had the chance to buy the entire 04 for the swap my question is what are you guys doin with the hydroboost is is possible to swap all the 04 hydro equipment into the older truck or am I better off finding an oem 70s hydro system im rebuilding the lq4 with a big cam an plan a disc brake swap in the rear an feel I could benefit more from the hydro set up thanks for the input
Scottsdalenstein78 is offline   Reply With Quote
Old 12-16-2014, 03:02 PM   #2
Kim57
Kim57's Avatar
Re: Hydroboost question
It should work just fine.
My hydro-boost came out of an 05 truck and my engine/trans is from an 07 Trail blazer.
The hydro gets its assist from the power steering so the year shouldn't matter.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-16-2014, 03:06 PM   #3
Custom 68
Custom 68's Avatar
The only things I would question are the master cylinder and prop valve. I believe most of the hydro parts are the same, I swapped a different master cylinder and used my current prop valve when I swapped mine.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-16-2014, 05:54 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine is a 71 gear, a 2006 pump, and a 97 Astro Van all mashed together with some fittings...works well, almost too well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-16-2014, 06:19 PM   #5
Scottsdalenstein78
Thanks for the replies so to get this straight (it's been a long day ha) the complete 04 hydro system should fit into my 78? An ill be using the match in 04 ps punk so no worries there but what about lines to my 70s gear box I assume the 04 is metric threads where my box is standerd do make new lines with standard an metric ends or are there adapters or find a later 80s metric box
Old 12-16-2014, 06:47 PM   #6
Possmguts
Possmguts's Avatar
Considering doing a hydro setup too since I have a big cam.
Would love to see a pic or 2 of this setup...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-16-2014, 08:21 PM   #7
Scottsdalenstein78
Ok here's the little bit I figured out every ome probably is already aware but just in case the modern or in May case the 04 hydro which are metric will work in a mid 80s metric gear box an the 70s or in my case the 78 brake lines will work in the 04 master cylinder both are fine thread 1/2" an lookin at the 04 hydro system an the fire wall on the 78 it looks feasible but how much doin it'll take im not yet sure maybe some one else can chime in hope this helps some one
Old 12-17-2014, 11:45 AM   #8
Custom 68
Custom 68's Avatar
Here is a quick pic of mine.
Dave
Old 12-17-2014, 12:43 PM   #9
ls1nova71
ls1nova71's Avatar
The hydroboost isn't all that hard to make fit, but it will require some fabrication work, about like putting the 6.0 in your truck. If you could find one off of a square body you would be time and trouble ahead. I switch the power steering boxes to the newer O ring fitting type for a couple of reasons, first, they are not as old and can be found in salvage yards easier than the older ones, and usually don't leak as bad. Also, they steer a little quicker, not super quick, but more modern feeling. Lastly, since the pump, hydroboost and box all have the same fitting types, you can use factory hoses. I get mine from RockAuto pretty cheap. Here's a pic of mine, and a link to one of my build threads showing how I did it and what hoses I used. http://ls1tech.com/forums/conversion...-c-10-a-5.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-17-2014, 01:49 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Take a look under my threads; I have a rebuild of the actual unit if you want to see inside it, as well as the put-it-together process in my build.
Old 12-17-2014, 02:14 PM   #11
Scottsdalenstein78
Hell yea thanks guys
Yea I'm not to afraid of fabing up the 04 unit into the older truck I looked at it a little last night an the base that mounts to the fee wall on the 04 was about 6 1/2 " wide an the brake booster base on the 78 was 4" or somthin like that I think I can cut the upper part of the "pan" on the 78 that brake booster sits in im fairly certain I can make it fit right
An il be sure to defiantly check out your guys builds
