Old 01-02-2015, 11:49 AM   #1
elimontfort
elimontfort's Avatar
6.0/4l80 first start
https://m.youtube.com/watch?v=wRPogy...ature=youtu.be
First start of my swap. It's a LQ4 with a set of 241 heads and a ls3 cam and valve springs.
elimontfort is offline   Reply With Quote
Old 01-02-2015, 12:28 PM   #2
elimontfort
Re: 6.0/4l80 first start
Engine bay pic
Old 01-02-2015, 03:54 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Hell yea! Nice work. Needs moar cam.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-02-2015, 04:15 PM   #4
elimontfort
No it needs a pair of these!
Old 01-02-2015, 05:10 PM   #5
Wasted Income
Boosted Member
Why can't you have both? They work pretty well together
Turbo diesel
Old 01-02-2015, 05:24 PM   #6
elimontfort
Money that's a rebuilt 6.0 and a gm reman 4l80. Eventually I wanna boost it but I didn't want the truck sitting for months or years waiting to do it all. I like driving that thing and it would kill me to just have it sit.
Old 01-02-2015, 05:44 PM   #7
Wasted Income
Boosted Member
Well there you go.
Turbo diesel
Old 01-03-2015, 12:26 PM   #8
earl84
Awesome, congrats. That must have been a great feeling.
earl84 is offline   Reply With Quote
Old 01-07-2015, 04:02 AM   #9
l92powered77
Thumbs up Re: 6.0/4l80 first start
hell yeah!!!! sounds awesome man congrats elimontfort !!! .. what did you use for headers? and mufflers? motor mounts? give us the details man come on..post more video of that bad a$$ !
l92powered77 is offline   Reply With Quote
Old 01-07-2015, 10:30 AM   #10
elimontfort
L92 it's a lq4 with cathedral heads, a ls6 cam and valve springs. I used cpps swap kit. It came with the Doug thorley headers. I couldn't use the crossmember out of the kit it was too wide for some reason it stuck out past the frame rails by almost a inch. So I used my 700r4 crossmember from bowtie Overdrives it worked fine on the 4l80 and gave me more room for the exhaust. I'm not sure what mufflers I'm gonna run I have a set of 40 series flowmasters but I think I wanna switch but not sure yet. Still have a bug to work out on the motor my ltfts for bank two are way too high almost on the 23 range and I'm getting a p0174 code for bank 2 lean. I know it's not a vaccum leak so I'm gonna swap the injectors over this weekend to see if it moves. I'm also waiting for my aluminum drive shaft to get made then I can do some donuts.
Old 01-07-2015, 12:59 PM   #11
elimontfort
Post Re: 6.0/4l80 first start
Pic of the truck. And I realized I put ls3 cams and head in the first post it's ls6 junk in there!
Old 01-07-2015, 01:13 PM   #12
slowcpe
slowcpe's Avatar
Nice. Cool truck. I can't wait to get my 6.0/4l80 running in my truck but I first have to learn how to make decisions
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-07-2015, 01:27 PM   #13
elimontfort
I finally said f it and did it. I ordered the motor and trans sept 16th got it oct 29th and fired it up jan 1st. It wasn't that bad but some things I wish I had done different. I highly recommend pulling the front clip to install the engine and trans together. I have a 4 inch drop and couldn't get it in so I had to break it apart. The trans is HEAVY and TALL and doing it on the ground was a pain by myself even with a trans jack. I like your stepper slowcpe. I wasn't a fan of them but they are growing on me. if my bed was trashed I would probably convert it but its in really good condition.
Old 01-07-2015, 03:15 PM   #14
tinydb84
tinydb84's Avatar
Nice set up!!
Once I actually pulled a front clip and learned how ridiculously easy it was I will never install another engine without pulling it again.
David
Instagram: myfabguy
Old 01-07-2015, 03:26 PM   #15
Wasted Income
Boosted Member
Yup. Front clip comes off every time the engine comes out. WAY easier to work on stuff that way.
Turbo diesel
Old 01-07-2015, 04:42 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IF someone would make a flip-nose front clip for the 64-66 that actually was any good, I'd be on one in a second. I love being all steel, but if I could dump 150lbs off the nose AND make it easier to work on....whooo I'd be all over that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-07-2015, 05:27 PM   #17
slotard
I guess I'll have to plan on pulling the front end off my truck when I put an LS in it. I wonder if it's ever been off...
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-07-2015, 06:46 PM   #18
slowcpe
slowcpe's Avatar
Yeah we ended up pulling the whole front clip to get the 6cyl out. Just made things easier but now turned my truck into a full frame off. My front clip was a bit of a pain to get off due to rusty bolts, but if I put fresh ones in, it would probably be a piece of cake the next time.
Thanks elimontfort
Ryan
Old 01-07-2015, 08:46 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Did you pull each peice off, or just pull the clip as an assembly? Its the difference between a 30 minute process and 2hour process lol.
Old 01-07-2015, 10:52 PM   #20
slotard
Can it seriously be done in half an hour? If so, is that true for square bodies as well?
1973 C20, 350/350
Old 01-07-2015, 10:58 PM   #21
tinydb84
tinydb84's Avatar
Depends on what you have hooked up already.
I had my radiator out and fender wells out. Might have been less than half an hour to be honest. You need a second person (or two) to lift it off. It is much easier if your wheels are off to.
David
Instagram: myfabguy
Old 01-07-2015, 11:53 PM   #22
l92powered77
Whoa! man she looks really nice really like her stance. Cant even imagine what you feel gripping the steering wheel knowing you got LQ4 lionheart in your truck. Actually got my 77 after i couldnt find a c10 like your body style. Congrats man nice truck and really dig the 6.0 swap. thanks for the informative reply.take it easy
Old 01-07-2015, 11:56 PM   #23
slotard
I guess I'll have to try that when I do an LS swap. Of course, first I have to find somewhere to do it, no garage for now
1973 C20, 350/350
Old 01-08-2015, 10:51 AM   #24
Chris Coufal
Awesome!!!!! Can't wait to start mine!!!
Chris Coufal is offline   Reply With Quote
Old 01-08-2015, 11:29 AM   #25
Wasted Income
Boosted Member
Assembly.
Turbo diesel
