01-11-2015, 02:05 AM | #1 |
At the body shop.
All that glitters isn't gold
Oil pressure has been acting goofy. Been a good run with this one. 100+ passes and 5k+ on the street, will look deeper tomorrow
" That didnt make it any newer " " Dont antique the equipment " |
01-11-2015, 09:31 AM | #2 |
Re: All that glitters isn't gold
Not good. Got little wear going on. Good luck.
01-11-2015, 10:49 AM | #3 |
Registered Truck Offender
Trying to figure out what I'm looking at here. Is that the engine oil pan, or the Trans pan???
If thats the trans,,,, dude thats not bad at all for 5000 miles and 100 passes but.... Mentioning oil pressure it is engine right???,,, I think I'd pull the distributor first thing and inspect the bronze distributor gear. Just doesn't look like bearings to me! Gotta be a thrust washer, spring shim, distributor gear,, If you've been using a good filter (hopefully) might just be a cleanup and some soft part and back for another 5000 / 100
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
01-11-2015, 12:54 PM | #4 |
At the body shop.
That's in th drain pain for the engine oil.
No brass gear for the distributor. Going to pull more apart today.
01-11-2015, 12:55 PM | #5 |
mini truck racer
X2 on the distributor gear. If that was bearing you would be hearing it .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
01-11-2015, 05:17 PM | #6 |
At the body shop.
The usually 80 psi has been fading to 50+/- and 10 psi at idle then comes back up to 30psi. Something is self clearancing.
01-11-2015, 05:21 PM | #7 |
Ouch,, yup not sounding good. Cam bearings would be my first suspect if she's not knocking.
01-11-2015, 05:29 PM | #8 |
I would pull the cam first. I have seen a rear cam bearing separate and allow the oil to dump. The bottom end will get pressure but hardly anything up top. Obviously everything needs checked but I would work from the top down.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-11-2015, 06:07 PM | #9 |
At the body shop.
Hyd roller cam. Lifter haven't made a peep.
Gear looks good
01-11-2015, 06:17 PM | #10 |
At the body shop.
Fwiw the pickup tube broke 5 years ago. Had oil pressure dropped the pan swapped pump pickup and pan. And been beating it ever since.
So maybe that failure is showing it's face
01-14-2015, 08:55 AM | #11 |
What did you find out?
01-14-2015, 06:17 PM | #12 |
And..... I was just looking at the wear pattern on that distributor gear. Not being able too see what the other face of the gear looks like... but kinda appears to be riding pretty high. When it goes back together might want to revisit distributor depth especially if this is a slip-collar
01-14-2015, 10:45 PM | #13 |
At the body shop.
Dropped the pan. Looked good no obvious grenades. Said F it. I'll pull the trans at the same time and freshen up both.
I thought the pattern was awfully high. Its a fixed distributors
01-14-2015, 10:52 PM | #14 |
At the body shop.
Bore looked better than I figured.
01-14-2015, 11:29 PM | #15 |
Have you pulled a valve cover yet?
01-15-2015, 01:21 AM | #16 |
At the body shop.
No. I'm going to this weekend.
01-15-2015, 10:15 AM | #17 |
You don't see any 'BIG END' of rods that are as discolored as the pin end of the one in the pic? Man someone got that one pretty hot to slip the pin through? Or just cooked oil?
Hopefully all looks as good as that bore!!! Being diligent and watching our for teh motor may have paid off big time. Hope you continue to find good things.
01-15-2015, 11:14 AM | #18 |
At the body shop.
All of the pin ends look like that. Struck me as weird too.
01-15-2015, 12:04 PM | #19 |
mini truck racer
The heat marking on the pin end is from the hot box used for pin installation if all of them show the signs . Not likely to have 8 burnt up pins . I don't run press fit because of this . I don't like taking a new treated rod and cooking it to expand it . Just doesn't seem correct . Been done a million times though .
Very interested in the outcome also . A lot of metal in the oil . Something is wearing . Hope its an easy fix .
01-15-2015, 03:16 PM | #20 |
At the body shop.
It's coming out this weekend. I'm very curios too.
If the block isn't hurt, going to bump the compression a better rod and port the heads.
01-17-2015, 05:30 PM | #21 |
At the body shop.
Well it seem's like this is the only issue I can see? Mains have some minimal wear. Second time it's done this
01-17-2015, 06:45 PM | #22 |
Hmmm who's lifters?
Hopefully that's all there is to it. seems like a lot of debris for just one lifter / pushrod.
01-17-2015, 06:50 PM | #23 |
At the body shop.
I know. But the material seems to be consistent with the retainer.
Its happened before too. I have the old set somewhere. Do you believe that could be the oil pressure issue though
01-17-2015, 09:52 PM | #24 |
At the body shop.
Found the old lifterm in my junk drawer.
This one made noise but no oil pressure fluctuations, but was a different gauge.
01-18-2015, 03:46 AM | #25 |
Lighter valve..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
