Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-23-2015, 09:56 PM   #1
Advanced Design
Advanced Design's Avatar
Swag 20 ton finger press brake
Somewhere in internet land I read a reference to a Swag press brake and how handy it was for their shop.
So, I checked out their product at the company website, viewed their videos about the press and found one on Ebay from them for less than on their website.
They sell an unwelded one that fits in a flat USPS box and they included the shipping fee in the price of their product. Their reasoning for the unwelded unit is if you want to bend metal like this you can probably weld...like their thinking.
Ordered it on Tuesday and it arrived on Thursday with our postman huffing and puffing it to the front porch.
Unit is well built, made in Oregon and includes a depth stop for repeat procedures.
Advanced Design is offline   Reply With Quote
Old 01-23-2015, 10:08 PM   #2
Advanced Design
Re: Swag 20 ton finger press brake
I only grabbed a few pictures when we were assembling it up at my neighbors shop. The pins to the side press into the base half way, then you weld them on the bottom.
We used the press shown because that is what he has. He built it about 20 years ago.
The base is formed to cradle the angle iron forming the bottom of the press area.
Old 01-23-2015, 10:16 PM   #3
Advanced Design
The top (finger) side of the press uses guides to control the position of the finger assembly during the pressing process. Instructions suggested to "eyeball" the guides half way fore and aft.
Wasn't good enough for my buddy. He straight edged it and measured to position them.
Welded in position.
Old 01-23-2015, 10:22 PM   #4
Advanced Design
Wanted to try it out so I used my 12 ton press on this piece of 1/4" material.
It worked fine and I will put one of the 20 ton bottle jacks in the press to make it a little easier.
And I need to grab some longer plates for the bridge base.
So far I am pretty pleased with the finger brake. Will try some lighter material as that is the majority of my fabrication.
Old 01-24-2015, 09:24 PM   #5
Advanced Design
I tried the press brake today on some 16 gauge and it really doesn't get a 90 degree bend. Maybe I can think of an insert for the base to be able to get a true 90 degree bend.
Swag website and videos state a 110 degree bend is possible. I suppose it is if you measure from the other side?
I did get the 90 degree bend I was after.
Old 01-24-2015, 09:42 PM   #6
franken
I've been wanting one of those.
I'd think a slightly better design would use 2 pieces of angle to form the V on the bottom, possibly with one or both shimmed slightly so the V was a bit less than 90 degrees. This would bend a bit past 90 to allow for the elasticity of whatever is being bent.
You might get a piece of say .75" angle the same width to lay on one side to simulate the bed being less than 90...
franken is offline   Reply With Quote
Old 01-24-2015, 09:47 PM   #7
Advanced Design
Great idea and I will give them a try. Thanks Franken!
Old 01-26-2015, 08:08 AM   #8
PGSigns
PGSigns's Avatar
Getting rid of the radius in the bottom piece of angle may do the trick. Should allow the finger to get that last bit of bend needed. I know the dies we have at work are a clean tight vee in the bottom. Does look like it would be a nice addition to the shop for making brackets and mounts.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-26-2015, 09:33 AM   #9
cg285
i had to build dies for mine in order to do shorter length bends
cg285 is offline   Reply With Quote
Old 01-26-2015, 01:35 PM   #10
truckster
truckster's Avatar
I'm thinking of making one with the vee in the bottom made of two pieces of flat bar welded together. That way I would eliminate the radius in the bottom of the angle. I could even make the angle a little tighter, if I need to, to compensate for metal springing back after bending.
truckster is offline   Reply With Quote
Old 01-26-2015, 04:33 PM   #11
michael bustamante
michael bustamante's Avatar
what link did you use for the e bay finding?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-26-2015, 08:08 PM   #12
notchbackgta
They sell another "die" for thinner pieces of metal. it is just a flat plate on the bottom with two pieces of metal, same thickness, half as wide as the bottom that are slotted at the ends for bolts to slide. You move the top plates in and out to get your 90 degree bend on the lighter material.
notchbackgta is offline   Reply With Quote
Old 01-26-2015, 08:25 PM   #13
Advanced Design
http://www.ebay.com/itm/271303190338...%3AMEBIDX%3AIT
Hope this helps.
Old 01-26-2015, 08:28 PM   #14
Advanced Design
I saw that on their website and didn't really understand what it does. Will have to check it out again.
Thanks for all the ideas guys. It does need a sharped V at the bottom.
Old 01-26-2015, 09:07 PM   #15
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Swag makes some nice stuff. I've been to a couple local shows and seen there stuff set up.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-26-2015, 09:21 PM   #16
Advanced Design
I was pretty impressed with their creativity and video's on their web site. And after following Rocktonka's build I have a hankering for their dimple dies.
Kinda spendy for no more than I would use them.
http://www.ebay.com/itm/281460832627...%3AMEBIDX%3AIT
Here is their adjustable V bottom Notchbackgta mentioned.
http://www.swagoffroad.com/FLAT-TOP-...Kit-_p_94.html
Looks like if will allow a 90 degree plus bend.
Old 01-26-2015, 09:26 PM   #17
CHIZZLER
CHIZZLER's Avatar
I have been looking for a quality used hydraulic press but no luck yet.
61-crew cab D-max
Old 01-26-2015, 10:07 PM   #18
Advanced Design
Chizzler, Swag kinda talks up the Harbor Freight unit that their press is designed for. Might be worth checking out.
I went ahead and ordered the flat top kit and hope I can use it this week end.
Old 01-27-2015, 12:39 AM   #19
CHIZZLER
CHIZZLER's Avatar
Thanks. i will check it out.
61-crew cab D-max
Old 01-27-2015, 03:37 PM   #20
_Ogre
_Ogre's Avatar
lots of peoples over on pirate4x4 forum that have these swag benders
many mods to make them work better/different, jigs and specialty bending heads
harbor fright has the air over hydraulic jacks that many of them use and straight electric/hydraulic conversions
shop air compressor timer
Old 01-27-2015, 05:57 PM   #21
crossfire84
crossfire84's Avatar
I don't see any bolt holes in the fingers. How are they held in?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-27-2015, 08:54 PM   #22
Advanced Design
Yhe fingers are clamped between the two flat bars. The second bar has the stepped edge to provide additional support to the fingers.
Here is a link to their page with a video demonstrating.
http://www.swagoffroad.com/20-TON-Fi...-Kit_p_86.html
Old 01-31-2015, 07:20 PM   #23
Advanced Design
The adjustable flat top kit showed up two days after ordering. It is a well made heavy piece and allowed me to bend beyond 90 degrees. The plates were adjusted all the way out.
If I took time to play around with it, I anticipate the degrees of bend could be controlled by the width of the gap between the two plates.
Old 01-24-2016, 02:21 PM   #24
diceman50
Thanks A/D, Very helpful.
"In an insane world a sane man must appear insane" ~Spock~
diceman50 is offline   Reply With Quote
Old 01-24-2016, 03:20 PM   #25
Advanced Design
Very welcome Ron. It is about right for no more bending than I do. It works well.
