Exhaust ideas for 6.0
Hello Fellow Members,
I have recently got my 6.0 ls swap to start the last weekend in my 1970 C10 2wd long bed. I am really disappointed that I did not take many pictures at all during the process (really drawn out process). I will post pics of the truck and a video of the truck running with only Doug Thorley headers. I still have plenty of work to do it, but I managed to hook up enough to hear her run (great motivation to continue). Back to the topic, I want to know and hear some of your exhaust set-ups that you have plumbed into your 6.0's! It will be a little while before I plan on getting the exhaust installed. |
#2 | |
The Older Generation
Re: Exhaust ideas for 6.0
I don't have mine that far along yet but welcome to the board from another Iowa boy. And yes, we want pictures... ![]() LockDoc
Boosted Member
I don't really have a decent idle clip, but it's a cammed LQ4, longtubes, dual 3" stainless exhaust with Magnaflows, no x or h pipe, dumped at the rear axle.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#4 | |
Thanks for the welcoming, i have been a member for a while but with very little posts (too much reading and learning). Only way i was able to get through most of my issues was to read through these forums for hours at a time! PS. I just recently moved back to SD, thanks for reminding me to update that. |
Pics from when I first brought the truck home.......
Pic of the pickup before starting with the new 6.0 ls based engine. I don't take a lot of pictures and now I regret that fact.
![]() Join Date: Jan 2015
the truck motors like to have an H or X pipe...more torque too
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
![]() Join Date: May 2011
According to the exhaust program I have, if your engine is a stock LQ4 and you have Doug Thorleys on it your exhaust diameter should be 2.75" to 3", you should have an H in the system 19.4" behind the end of the 2nd primary pipes and a muffler 38.7" back form the 2nd primary into chambered mufflers approximately 370 cubic inches in dimension. After the muffler it doesn't really matter what you do as long as you keep the diameter at least the same size as goes in it. I would personally go with 2.75" pipes because you will reach volumetric efficiency sooner and start creating power lower in the rpm range.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
meowMEOWmeowMEOW
You won't find 2.75 as much at exhaust shops or parts stores as you might hope....at least not the "commercial" ones. The universal stuff is all sold in 2.5 or 3" for the most part.
The actual custom exhaust places, tubing companies themselves, and online you can still get 2.75". Just my random observation.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#12 | |
#13 |
meowMEOWmeowMEOW
Or just run 3" pipe since bench flowing exhausts is still ballparking (just really good ballparking). Most setups wouldn't notice the difference, and since so few of these things stay stock intake/cam/heads you'll end up wanting the 3" anyway.
I'm not discounting your calc, which does offer a lab-ideal result. I just think that even with a program, there are factors that aren't being accounted for. Especially if I were considering a stainless system where cost is a factor, I'd rather build a 3" system I'm less likely to outgrow.
#14 |
I'm really happy that I have been receiving this information. Some time down the road I may look at swapping the cam, but for now I just want the thing running for me! More information is welcome as I still have a lot to learn and over research before making a decision!!
For some reason I am having issues with adding the video from my iPhone of the start up. Is there an easy way to do this? |
#15 | |
#16 | |
Hey that sounds really mean!
![]() ![]() Quote:
#17 | |
Boosted Member
LS6 intake from a CTS-V. 4L80E with a 3600 stall Ebay aluminum radiator that i welded bosses to, to mount a junkyard dodge intrepid dual fan to. GM 0411 ecm tuned by me with EFI Live. Has a custom operating system for the nitrous. Harness was modded by Speartech years ago.
#18 |
Here is a 78 with a 2.5 H pipe and walker muffs
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
