Old 02-26-2015, 04:51 PM   #1
Gary66
Gary66's Avatar
Rockwell t221
Where can I find one.... Mine went out.....
2003 2500 HD Crew Cab
1965 GMC K10
1972 Chevrolet k5 blazer
Gary66 is offline   Reply With Quote
Old 02-26-2015, 09:39 PM   #2
bigrigpardo
Re: Rockwell t221
you saw mine in the ad. PM me we should be able to work something out.
andrew
bigrigpardo is offline   Reply With Quote
Old 02-27-2015, 04:55 AM   #3
andrewmp6
Re: Rockwell t221
Only way i would put another one back is if you want your truck 100% stock.If not i would use a np205 or even a np203.
andrewmp6 is offline   Reply With Quote
Old 02-27-2015, 11:59 AM   #4
Gary66
Gary66's Avatar
Re: Rockwell t221
By changing it out would require changing the brackets and both driveshafts, wouldn't it?
1965 GMC K10
Old 02-27-2015, 01:59 PM   #5
BLT gmc
Re: Rockwell t221
Shifters are in a different location. Rockwell T-221 is on the drivers side of the high hump. Cross member is different. Drive shafts are different.
BLT gmc is offline   Reply With Quote
Old 02-27-2015, 02:21 PM   #6
Gary66
Gary66's Avatar
Re: Rockwell t221
And those are the reasone I will keep a t221 in it......
1965 GMC K10
Old 02-27-2015, 02:55 PM   #7
61K10
61K10's Avatar
Re: Rockwell t221
whats wrong with it?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-27-2015, 03:12 PM   #8
Gary66
Gary66's Avatar
Re: Rockwell t221
Well evidently it had a crack in it when I bought it and the PO neglected to tell me about it.... Got it here and used it in the snow.... After a day it popped out of 4wd.. Crawled under it and it has a nasty crack in it.... I don't think I can weld it where it cracked.... Soooo... Hence looking fear a replacement
1965 GMC K10
Old 02-27-2015, 05:40 PM   #9
BLT gmc
Re: Rockwell t221
Crack in the t case or the adaptor? I have seen the adaptor for sale on this site. I will run my T-221 also, there are a few of us left. Detents may need tbe looked at also. Bruce
Old 02-27-2015, 05:44 PM   #10
dieseldude4bt
Re: Rockwell t221
I assume yours is married? not the divorced T221 correct.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 02-27-2015, 05:52 PM   #11
Gary66
Gary66's Avatar
Re: Rockwell t221
It is divorced
1965 GMC K10
Old 02-28-2015, 12:04 AM   #12
mattbert56
mattbert56's Avatar
Re: Rockwell t221
There are a few on ebay i have seen recently. not mine. But I have seen them in the past. Shipping would be a nightmare. But its dependent on how bad you want it. Best of luck. I just finished repairing mine. Everyone says to change to an np205. I still like the t221. May have a bit more gear noise. But it's a truck.
mattbert56 is offline   Reply With Quote
Old 02-28-2015, 02:56 AM   #13
argonaut
argonaut's Avatar
Re: Rockwell t221
I would recommend retrofitting a divorced np205 from a dodge. You can find these without too much trouble. Should be fairly straight forward to make some brackets to mount in place of the t221. Front driveshaft shoukd be the same and I bet that the rear driveshaft could be reused as well even though the output is high on the np205 versus low on the t221.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-28-2015, 03:55 AM   #14
andrewmp6
Re: Rockwell t221
I'm with argonaut a np205 would be better in the long run you can get parts for it anywhere if you need them.The rockwell parts are like rooster teeth.
Old 02-28-2015, 06:11 PM   #15
Rotorcycle
Re: Rockwell t221
Craigslist , do a search all or Ebay. Have a solid mount bare case but not sure if it's the same as a divorced case if it helps
Rotorcycle is offline   Reply With Quote
Old 03-01-2015, 11:16 PM   #16
Bad4wd
Re: Rockwell t221
Here's one...
http://sacramento.craigslist.org/pts/4882218457.html
Bad4wd is offline   Reply With Quote
Old 03-12-2015, 01:39 PM   #17
1960chevypanel
Re: Rockwell t221
PM sent
1960chevypanel is offline   Reply With Quote
Old 03-13-2015, 10:18 AM   #18
BLT gmc
Re: Rockwell t221
searchtempest is the bestsearch engine. I just picked a NOS T221 bearing seal kit out of MN, because of searchtempest. Bruce
Old 03-13-2015, 11:31 AM   #19
Gary66
Gary66's Avatar
Re: Rockwell t221
I got a transfer case from a forum member.. It was rebuilt and in excellent condition. Drove to Indy to pick,it up went in smooth and I'm back on the road. Thanks to all for help and advise.
1965 GMC K10
