Old 03-02-2015, 10:54 PM   #1
feller
feller's Avatar
original axles
I bought a 72 roller for parts, P.O. put newer axles under it 44front and 14 bolt out back, was the 14 bolt available in a 72? I really would rather have the 60 ho72 combo but you don't see those everyday, and parts and gear ratios are kinda tough, I would like the ability to drive everyday without putting a set of 38's on it.
feller is offline   Reply With Quote
Old 03-03-2015, 01:34 AM   #2
argonaut
argonaut's Avatar
Re: original axles
Corporate 14 bolts were introduced in 1973. Is this a 3/4 ton or 1 ton?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-03-2015, 03:04 AM   #3
andrewmp6
Re: original axles
If the 14 bolt is a full float you can sell it and make a few bucks.
andrewmp6 is offline   Reply With Quote
Old 03-03-2015, 08:47 AM   #4
68panelman
68panelman's Avatar
Re: original axles
You will be better off with the 14 bolt. Like you said parts are hard to come by for the Eaton rears. Try finding new drums or bearings for them.
68panelman is offline   Reply With Quote
Old 03-03-2015, 08:48 AM   #5
feller
feller's Avatar
Re: original axles
I'm unsure of the axles I have right now, just knew they weren't original to the truck, but didn't know if 14 bolt was an option in 72, my truck is actually a 1/2 ton but wanting to put 3/4 axles under it and call it a k20
Old 03-03-2015, 09:38 AM   #6
Re: original axles
If you have a 14-bolt in the rear I'd leave it. If you have a Dana44 in front you have what the '72 came with, but smaller hubs seen. It could be a 10-bolt which is pretty equal. All thhe 10-20 series 4wds used the same axle in front with 8-lug on 20s
Old 03-03-2015, 10:15 AM   #7
andrewmp6
Re: original axles
Take some pictures of the axles we can id them.
Old 03-03-2015, 10:33 AM   #8
argonaut
argonaut's Avatar
Re: original axles
In your first post you mention 60 and ho72. Those would be 1 ton axles. It confused me and I thought maybe you were trying to make a hybrid 1 ton pickup.
I also agree that removing the 14 bolt would be a step backwards unless you are going for a factory restoration.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-03-2015, 11:13 AM   #9
gerfunken
gerfunken's Avatar
Re: original axles
I didn't think that there was a 1-ton 4x4 from 67-72, but a 3/4-ton would have used the 8-lug Dana-44 up front and the Eaton HO52 in the rear. Mind you, it's been a while since I searched for specifics in the forum. I thought that the HO72 was 1-ton and up, and typically had like 4:10 - 5:13 gearing.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 03-03-2015, 01:40 PM   #10
argonaut
argonaut's Avatar
Re: original axles
I've never seen 67-72 K30 either (not to say that they don't exist) that's why I thought maybe the OP was going for a "hybrid" setup.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-03-2015, 02:54 PM   #11
feller
feller's Avatar
Re: original axles
OK I was a little confused about the 72/52 thing, what are the major differences between them, I know 3/4 and 1 ton, I mean internal and external stuff
Old 03-03-2015, 07:01 PM   #12
gerfunken
gerfunken's Avatar
Re: original axles
I'm not entirely certain that I can give you a single specific answer. Before I swapped my rear-end out, I did a bunch of research since you couldn't find parts for the old Eaton rear-ends any more. I found that there are some places that do still make a bolt-on disk conversion for the rear, but I was reluctant to go that direction. Among the reasoning was that you couldn't find different gears or bearings for it directly, and you'd need to do a lot of research to get matching parts. Since I'd planned on going diesel, I knew that I couldn't survive with 4:10 gears... I'd never get above 55MPH.
Anyway, Google provides the best places to get answers.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 03-03-2015, 07:20 PM   #13
feller
feller's Avatar
Re: original axles
Yeah the gears are a big reason I don't really want an Eaton, I wasn't too worried about parts cause the way I understand it is that its hard to break them, and I've read that with the right stuff you can run 14 bolt shafts and apparently the 14 bolt disk kit can work too, this is just what I understand from my reading
Old 03-04-2015, 08:15 AM   #14
Re: original axles
Some HO52s have the side load bolt in the front of the differential housing and all HO72s do. The only other difference is in the backing plates-out...or the brakes and bearings. 14-bolts and later front Dana 44s, as well as 10-bolt, can be found with 3.73s and even 3.42s (or other tall ratio there abouts). I don't think Dana 44s went taller than 3.73
Old 03-04-2015, 09:38 AM   #15
feller
feller's Avatar
Re: original axles
Yeah I would like to stick around 3.73 or so, planning on running a 33" tire and that combo is not too bad on gas
