Old 03-03-2015, 11:42 PM   #1
blazercrazy70
blazercrazy70's Avatar
Can you use your stock crossmember
I am sure this has been asked just wondering if you can use your stock transmission crossmember with a 4l60e
blazercrazy70 is offline   Reply With Quote
Old 03-03-2015, 11:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Can you use your stock crossmember
Yes, I used my th350 crossmember in my Panel truck. Bolted up to the factory holes and the driveshaft fit.
LockDoc
Leon
Old 03-04-2015, 03:12 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yep, you can use it for any of the trans options. The only differences are length (so slide it back and drill new holes), and what rubber mount sits on top. When I switched to an 80e, it used an extra center hole, but thats it.
Prob the easiest step in the swap, 20 minutes and your done.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
