04-17-2015, 03:31 PM | #1 |
1976 Crew Cab Long Bed Camper Special resto-mod
i guess its time to start one of these.
i found the truck in the classified here, but it was 700 miles away from me. after several emails and phone calls and text messages i purchased the truck from a good seller. he purchased the truck from the original owner. he did an incredible job swapping in a 1998 Cummins 5.9l 12V motor with its 47RE with electronic torque converter lock up and electronic overdrive. otherwise, this truck is completely stock and clean!! i got the truck back to louisiana and started driving it. i put ~4 tanks of diesel through it and i think i have a good idea on what needs to be done and what i want to be done. needs: AC Installed - truck has vents and low side equipment. engine has compressor mounted already. just need to mount the condenser behind grill and plumb and charge the system. front brakes squeak real bad - replaced pads air bags all around linex in bed weatherstripping on doors needs replacing. now second battery for starting duties the trailer wiring needs to be fixed KDP needs to be addressed Amsoil all around wants: LED lights - replaced. had to put the tails and flashers back to incandescent to ensure operation. all of the running lights are LED, interior and cab and rear clearance. i'd really like the big ass spike lug nut covers, but i'm having trouble finding them for the 1" lug nuts i have fix cargo light fix lights for tranny controls feedback some of the trim screws are rusting so i need to replace any household screws with SS screws. seat covers and floor mats - in the process so here is my location to document my progress |
04-17-2015, 03:32 PM | #2 |
Re: 1976 Crew Cab Long Bed Camper Special resto-mod
here is how the PO found the truck
and then how i purchased it: |
04-17-2015, 04:41 PM | #3 |
the jewel under the hood.
04-17-2015, 05:01 PM | #4 |
first order of business was to quit slamming doors!!!
so these came out and these went in |
04-20-2015, 11:42 PM | #5 |
Thats a drool worthy beast. Yup.
04-22-2015, 08:37 PM | #6 |
. Looking forward to following your progress - great truck! Keep us updated w/ lots of pics. . . |
04-22-2015, 09:52 PM | #7 |
That thing is awesome. I love the cummins in there.
http://67-72chevytrucks.com/vboard/s...d.php?t=667072 |
04-23-2015, 12:06 AM | #8 |
I had a 79 crew i had started a 12 valve conversion on that I had to sell, i always wanted to do one. Nice rig!
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-23-2015, 08:18 AM | #9 |
nice truck =0)
dont want to hear excuses, i want to hear solution(s) |
04-23-2015, 09:28 AM | #10 |
thanks guys,
ill be slowly plugging away at things needed i know some of you are on the west coast, but for the rest of us, its spring and torrential rain is all around. i found this last week: nothing like a little water on the floor board to strike fear in my heart so this came yesterday: i should get these installed over the weekend before the rains come back |
04-23-2015, 09:32 AM | #11 |
i was also chatting with my title guy when i did the paper work and he said they could re-issue old plates to vehicles so i went and found an old plate, and shot some paper work off to the state. i should know something within 5-10 working days.
i'd love to see this on the back of the truck: |
04-28-2015, 12:28 PM | #12 |
04-28-2015, 07:30 PM | #13 |
Nice Rig.
I would check the mounts for the windshield visor for your leak. Good luck with it.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
04-28-2015, 07:33 PM | #14 |
check your clearance markers also.
04-29-2015, 10:02 AM | #15 |
thanks for the ideas, i replaced the marker lights recently, so i will make sure they are still tight, but i never thought to look at the visor mounts.
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE |
05-04-2015, 11:34 AM | #16 |
Supper nice rig you scored yourself! Following along for sure.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 |
05-04-2015, 01:31 PM | #17 |
Nice ride, hope you get the water situation figured out!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
05-26-2015, 09:49 AM | #18 |
i know some of you folks arent getting any of this glorious rain, but we are.
and im happy to report the new precision gaskets are doing their job well:
05-26-2015, 09:50 AM | #19 |
and i am also enjoying a little birthday present from a friend who knows my style:
06-12-2015, 12:56 PM | #20 |
little updates:
got my tint done finally. 20% ceramic all around. just to keep the heat down
06-12-2015, 12:58 PM | #21 |
i also got the AC charged up and working
its been super hot here lately, this is at an 83* exterior temp: an 11 degree delta aint bad, but i will run it for a while and check the freon levels. im sure there are some leaks or something with this older system
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE Last edited by rajincajintj; 06-12-2015 at 01:03 PM. |
06-12-2015, 01:02 PM | #22 |
aaand, if you look closely at that picture of the tint, i have a little issue with the rear view mirror on the driver side.
i clipped the garage door on the way out (in reverse) of the garage and ripped the mirror out of the door: literally almost cried. not quite sure how to fix that yet. a new door might be in the works. i'd like to try my metal working skills and make a newer thicker panel to mount these to and weld it in the door. who knows.
06-12-2015, 05:08 PM | #23 |
Damn that sucks. It can be fixed though!
My buddy took out his mailbox the same way. He wrapped the door of his Ford Ranger around the other way doing it. I couldn't believe he didn't notice until it was all the way against his finder....
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-13-2015, 02:53 PM | #24 |
Glad to see you got the water situation fixed, and I'm sorry to see about the mirror,
06-17-2015, 11:21 AM | #25 |
the mirror will be fixed. i think ill rock a mismatched door for a minute while i try to get this one fixed.
on to fixing more stuff: finally got around to putting power back to the rear clearance lights. looks like someone ripped the tailgate off at one point and left the wire hanging. all i needed was a butt connector and a length of wire. i also ordered some LED replacements. once the new ones come in, ill rewire the whole shebang. and i also got the cargo light lens replaced and the absolute LAST LED bulb i need on order. then the entire truck will be LED except for the front indicators and the tail lamps.
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE Last edited by rajincajintj; 06-17-2015 at 11:27 AM. |
