05-07-2015, 06:55 PM | #1 |
71 Burb with a leaning problem
Ok....I have been working on this tank for some time. Just started buttoning up the 3/4 ton axle swap and the DAMN thing is lower by a 1 1/4 on the drivers side. I first thought it was the springs so I swapped them out with a set of skyjacker lift springs....and still the same problem. When I set the skyjacker springs on the axle, and the axle was sitting on jack stands, it was level! When I put the tires on and lowered them to the ground, the burb then had the lean of 1 1/4" to the drivers side again.
I have checked the following : Tire pressure Body mounts Spring bushings etc... I checked the front of the frame and it was level....and pretty sure frame isn't tweaked because I don't remember if ever leaning at all. this one has me stumped....please help if u can!!! Posted via Mobile Device |
05-07-2015, 08:36 PM | #2 |
Re: 71 Burb with a leaning problem
Two different length shackles??
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
05-07-2015, 08:55 PM | #3 |
Yeah....measured those and they are same size. This is the weirdest thing I have experienced with this rig for sure
05-07-2015, 09:11 PM | #4 |
It is weird. so with the new springs mounted and the axle mounted, but axle on jack stands, it was level? Are you sure both jack stands were extended the same amount? can you simulate this by putting it back up on jack stands? is one of your tires mistakenly a smaller size!?!?!
Is the rear axle a 14 bolt, eaton or dana 60? Did you relocate the spring perches inward to 40"? Or did you convert to later model wider hangers at 42.5"?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 05-08-2015 at 02:17 AM. |
05-07-2015, 09:25 PM | #5 |
normal chevy lean they all do it to some extant the harder they were used the greater the lean
05-07-2015, 09:30 PM | #6 | |
05-07-2015, 10:12 PM | #7 |
05-07-2015, 10:27 PM | #8 |
With good body mount bushings, springs, spring bushings and shackles, there is no reason a truck should lean. At least not as mush as 1"+. Unless it is actually weighted heavier on one side, or something is on the chassis is bent.
If it sat level on the jack stands then the only remaining factors are the wheels and tires. The other puzzling thing to me is that there is no factory 3/4 ton truck (or 1 ton for that matter) with a 14 bolt that has the the same spring perch distance as a 71.
05-07-2015, 10:30 PM | #9 | |
SWB 4x4 Collector
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-07-2015, 10:40 PM | #10 |
My '63 leans about the same amount but on the passenger side. The only difference is that the front shackle on the passenger side has a little more angle. By a little Im talking within 5 degrees of the drivers side. Its driven me crazy for the last 8 years! In two weeks, Im swapping in a set of 52" springs into the front and at that time, I will make sure that the new rear shackle eyes and front spring hangers are in identical places. I can't tell you how many times Ive measured my frame with a straight edge and plumb bob only to come to the conclusion that the hanger was installed just a little off at the factory. Not sure if this is what you have going on with yours as well but its free to take a tape measure and look.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
05-07-2015, 11:39 PM | #11 |
Could be a bent frame , hate to bring that option up. I had the same issue on a prior resto, needed a tweak on a frame machine to fix it.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
05-07-2015, 11:56 PM | #12 |
05-07-2015, 11:57 PM | #13 |
Check the spindles. One may have 1" drop.
Just a thought. Posted via Mobile Device |
05-08-2015, 01:57 AM | #14 |
My thought is binding suspension, did you lower the driver side last with a floor jack? did you torque the U bolts up in the air or on the ground?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-08-2015, 02:26 AM | #15 | |
I dont mean to steer this off topic; the reason I bring this up is because if the OP has a 1 ton axle with 40.5" spacing installed on 40" wide hangers then spring bind could be causing some problems, whether they are causing the lean or not.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 05-08-2015 at 02:32 AM. |
05-08-2015, 02:31 AM | #16 |
Another thought: measure your springs from each end to to center pin. My 52" long tuff country 4" lift rear springs had slightly offset spring pins so I had to be sure to have both oriented the same.
05-09-2015, 07:02 AM | #17 |
Just throwing this out there since no one has mentioned it... Could the frame be cracked at the steering box? What surface is the truck on when measuring?
The last suggestions by argonaut could make a difference.
05-10-2015, 02:07 AM | #18 |
One thing for sure, this is not your usual problem. Very odd.
06-05-2015, 03:47 PM | #19 |
Did you ever find out what the problem was?
56 Chevy step-side 68 Chevy Suburban 69 Corvette Stingray 00 BMW 325 (Daily driver) 09 BMW M3 18 GMC Acadia (Wife's daily driver) |
