'69 chevy c-10 blower fan
Good morning all,,,,,I'm wondering if anyone in here has replaced the heater fan motor in their trucks? Mine is the original motor. I'm wonder if there is a more powerful motor(higher rpms) that I can put in it. I don't know if the replacement motor from LMC would put out more air,,,,. Any input would be great,,,,thanks,,Bill.
#2 | |
The Older Generation
Re: '69 chevy c-10 blower fan
Hi Bill, I think the blower motors for trucks with A/C might have a few more RPM's. If you are not getting enough air through your system now I would suspect a problem with junk or mouse nests in your heater boxes. If everything is clean and open in the heating system, and the ductwork is in place, the heaters and defrosters work great in these trucks. You could take the blower motor out and bench test it to see of it has any problems. That way you can check the squirrel cage for holes and check the outer heater box for debris and mouse nests.... LockDoc
X2 what Leon said. Also make sure its going in all 3 speeds. sometimes the fan speed lever doesn't put it in high speed.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
$20 at Oreilly.... bought one for my Blazer awhile back 'cause it was SQUEALIN'. Cleaned a LOT of trash out of there too.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
![]() Join Date: Sep 2007
ive read where some truck folk replace the plastic squirrel cage with a metal one.
1967custom |
Wide n'Low
![]() Join Date: Jan 2007
I thought there was a thread (might be in the 73-87 section) where guys were using the heater motor/cage assy. from something like a late 80's C30 with a/c. Supposed to be a direct fit, steel cage, and much higher rpm. I'll see if I can find it
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Wide n'Low
didn't find the thread i was thinking about, but saw a few reference the following.
Go to either O'Reilly or Autozone and tell em you want part number "pm129". I for some reason they don't wanna give it to you without looking it up give em a 94 chevy pickup k1500 with a 5.7l v8, and they'll pull up the number I gave you.
#8 | |
I don't think that one will fit. I think the squirrel cage is deeper. I was wrong once before though... ![]() LockDoc
K,,,,thanks guys,,,,,I don't have air on mine. I'll pull the box out under the hood,,,,,and mine sure sound or feel like its got 3 speeds. You can barely feel the air moving,,,,will check all of the above,,,,thanks again,,,,Bill
LOL,,,update,,,,I pulled the inside vent box,,,mouse nest,,,etc. Had to rework the flap that controls the air flow to the upper vents,,,couldn't find where to get one,,,,it'll be fine. Cleaned all the vents out,,got to get new hoses too,,,might as while I got it all tore out,,,,thanks again for all the input,,,,Bill
#11 | |
The outside box will probably be full too, on the other side of the heater core. It's not as easy to get off. LockDoc
I checked up toward the heater core,,,doesn't look that bad,,,took a air hose and gently blew air up in there while running the fan,,,
#13 | |
Wide n'Low
#14 |
